Doing my Research
Old Apr 6, 2007 | 05:48 PM
bigbikerdad81's Avatar
bigbikerdad81
Stage II
Default Doing my Research
Hello all, just signed up here. I've been saving all I could and now the idea of getting a night train is getting closer. Having said that I'm trying to get a couple questions answered. Not being a tire salesman or even close I'm looking for some answers there. The earlier NT's came with an 11.5-23 rear tire, what's that comparible to in mm(150mm...180mm)? I've come across a 99 and an 00 NT, being a fan of bigger rear tires I'll eventually want to put something bigger on. I'm not too interested in putting thousands into an all out kit, I am hoping there is a way just to put a bigger tire on with stock parts. With bigger tires must one put on a bigger rim? How will handling be effected? Will different years be easier or harder to modify?I appreciate all the help.
Old Apr 6, 2007 | 06:00 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: Doing my Research
Best bet would be to get an 06 or 07 as they come with the 200mm tires already on them.
Earlier bikes had 130 or 150's on them and to put a 200mm tire on takes a bit of money and some kits are not as nice because they offset the rear tire. If its got a 150 on it already I "think" you can get awy with a 180 "if" you go to the newer narrow belt, but I'm not positive so don't quote me on it.
Old Apr 6, 2007 | 08:53 PM
Softtail Bob's Avatar
Softtail Bob
I agree that you may want to wait and go with the 06 or 07 that already has the 200mm because any bike that does not come with the 200mm tire will cost you alot of money to convert. You are looking at a kit that will cost you $4000 or $5000 andwill have you changing the wheel, tire, fender, pully, belt, swing arm, and guards aswell as some other stuff like struts, lights, and license plate bracket.
Old Apr 6, 2007 | 09:04 PM
bigbikerdad81
Stage II
Thanks for the information guys. Now if I did decide to replace the stock tire with a 180, will I have to change anything other than the belt? How about the rim?
Old Apr 6, 2007 | 09:12 PM
L night train's Avatar
L night train
try 2 get an 06
Old Apr 6, 2007 | 09:14 PM
jimb's Avatar
jimb
I have an '02.To put a 180 I had to buy an aftermarket fender($285.00) tail/brakelight($120.00) get it painted($150.00) and run the wiring.Plus an 18x5.5 wheel, the cost can vary on that, a 180 tire, Avon is narrower than the Metzeler,and the pulley, belt, rotor and caliper are stock.
[IMG]local://upfiles/11733/C1C5D8FD3B96493A986D3102EDAF3208.jpg[/IMG]
Old Apr 6, 2007 | 09:18 PM
jimb's Avatar
jimb
It doesn't take 4 g's to do it.You do have to cut off the frame horns, the fender I bought came with a template to do that.It's not hard.I have no experience with a harley and other than paint I did it in a day.
[IMG]local://upfiles/11733/A73225E15893497D862D262976D5ACAA.jpg[/IMG]
Old Apr 6, 2007 | 10:55 PM
back again's Avatar
back again
you can do the 180/200 1500 or under depending on the wheel. seems that the 99 back are less expensive to do. it can be done with all harley parts also.
Old Apr 6, 2007 | 10:58 PM
back again's Avatar
back again
a 180 won't go under your fender.
raaaaaa
Sep 28, 2021 12:20 PM
hfp3030
Nov 8, 2012 05:21 PM
mimo
Oct 18, 2008 11:00 AM
BrendanGTStang
Sep 21, 2008 12:33 PM
fiftyonefive
Feb 7, 2008 09:01 AM
