Oil Leak
Old Apr 8, 2007 | 11:45 AM
monkey3's Avatar
monkey3
Default Oil Leak
I've got a slight oil leak on a 2006 night train. It is at the rear of the cases. It looks like it starts half way up and runs down the seem. Anyone else had this problem. Taking it to the shop Monday.
Old Apr 8, 2007 | 12:56 PM
JeffreyLebowski's Avatar
JeffreyLebowski
Default RE: Oil Leak
ORIGINAL: monkey3
Not sure what you mean "at the rear of the cases". Not a mechanic. My outer primary gasket was bad- leaked very slowly for about 3 years before I decided to have it fixed. Cost about $200 for the gasket change plus an oil change with some synthetic oil. If you post a picture you might get some better advice.
How's that Thundermax ECM working out for you?
Old Apr 8, 2007 | 01:36 PM
monkey3's Avatar
monkey3
Jeffrey, I really like the Thundermax. Put it on last Sept.
and I'm well pleased with the performance. As for pics I
have none to post but it's the bottom end of the motor,
what you would split to get to the crank.
Old Apr 8, 2007 | 03:10 PM
JeffreyLebowski
Ouch- that's a bigger deal than my oil leak was.
Did you get the autotune with your thundermax?
Old Apr 8, 2007 | 03:47 PM
monkey3's Avatar
monkey3
No autotune. I think I got mine before that came out.
Zippers installed mine and set it up at Ocean City then
didsome finetunningit at Myrtle beach 2 weeks later last fall.
Old Apr 8, 2007 | 05:24 PM
Grey Biker's Avatar
Grey Biker
Monkey, I have a 06 Heritage, I had a slite oil leak at the case seem under the bike. To make a long story short, the engine had to comee out and the cases were split and re-sealed. The mechanic at the H.D. dealer said he has done quite a few re-seals. Luckly my bike was under warenty.
Old Apr 9, 2007 | 07:05 AM
monkey3's Avatar
monkey3
Thanks for the info Grey. Mine is still under warranty as well
and the dealer has me scheduled in this afternoon. They are going
to put dye in the oil to verify the source then they need Harley's
blessing to repair.
Old Apr 11, 2007 | 12:42 PM
Grey Biker's Avatar
Grey Biker
They put dye in mine also. Good Luck.
Old Apr 11, 2007 | 01:49 PM
jimb's Avatar
jimb
I had a small leak at the rocker box(a lot easier than the cases) on my train when I first got it.Mechanic said a little peice of the black coating was still on it when it was assembled and that's what caused the leak.Maybe the same thing is happening with your cases.
1flhtk4me
Jun 1, 2018 07:46 AM
Mcnasby
Jun 29, 2012 05:02 AM
vindyl
Feb 26, 2011 10:31 PM
avfd123@yahoo.com
Exhaust System Topics
Jun 26, 2008 04:43 AM
Rhinoexpress
Sep 9, 2007 08:32 PM
