Valve train noises?
Old Sep 8, 2014 | 05:44 AM
Village Idiot™'s Avatar
Village Idiot™
Default Valve train noises?
How noisy is a TC88's valve train normally? I've been hearing a noise over the past couple rides and I wasn't sure if it's something new or I'm just being paranoid. At first I thought it was detonation as I was pretty sure I was already suffering from a minor bit of that when in the very low RPMs and hammering on the throttle. It sounds like the engine pops when the bike is cooling down after being off, just two or three of them before the RPMs start to climb and it smooths out. I normally don't ride in RPMs that low, so it hasn't been a concern.
Lately (at least I think it's just been lately) I've been getting simlar noises that are noticeable over the normal valve chatter right around 3,000 RPMs. It sounds exactly the same everytime I'm in that range and it's only under about 30% throttle. I don't really notice it while at 75%-100% throttle in that range and it has that same popping sound as a cooling engine.
The bike has a canned tune for the SE 205(IIRC) cam and 95" upgrade. It also has the SE'ish stage 1 on it.
Any ideas? Ride it 'til it asplodes? I haven't touched it since the Indy put it together and I uploaded the tune. I'm 99% sure I didn't screw up and put the low octane in it like I did the one time a long long time ago.
Old Sep 9, 2014 | 06:56 AM
Prw3's Avatar
Prw3
Ive owned several TC88’s and ALL had extremely noisy valve trains, like yourself I always wondered was this normal. After talking with several HD mechanics its the norm and nothing to be concerned about as its the design ( tons of spring seat pressure) and much of the noise is due to how the rocker boxes breath and deal with oil mist...yeah oil mist. Not to cause anymore anxiety but the TC88’s are better known for cam chain noise just prior to failure, If you plan on keeping your 88 by all means convert to a modernized cam drive setup. Other then that its a very good engine, good luck.
Old Sep 9, 2014 | 08:14 AM
Superfly3176's Avatar
Superfly3176
The popping after shut down is normal. Not sure if its heat dissipating or what but my cousins triumph does it too.
Usually you'll know if something is ****ed in your powertrain. Because it will be pretty loud.
Old Sep 9, 2014 | 10:27 AM
Village Idiot™
I know that is, I was just comparing the sound of the valve tap to it.
And /facepalm. Low oil. Dead battery was causing my odometer to reset so it looks like I'm close to due for an oil change. My TC likes to eat the oil, but when it gets lower, I remember the valve noise in the higher RPMs becoming more distinct. I'll put a quart in until I get my oil changed in the next few weeks.
Old Sep 9, 2014 | 12:53 PM
oct1949's Avatar
oct1949
(Never heard all that many complain about it)
(So, How long have you owned the bike..??)
(That not the best way to accelerate,, dropping a gear or two would be better)
That does sound like/could be Pinging
(How many miles on you bike/motor.. Maybe time to check the C-Ters.)
(Never heard of a SE 205 Cam.???.. they are not in the SE book of cams )
more input may help us give you a better/more answers...
Old Sep 10, 2014 | 06:28 PM
Village Idiot™
Strange, because most people say the TC sounds like a sewing machine. It's a 2006 I've had since 2012. I don't normally hammer on it at a low RPM, but testing that was where I found out about the "ping". It has about 22k-24k miles and only about 4-6k since the SE203 cams and cylinder/jugs upgrade. The cam tensioners were replaced at that time.
I topped off the oil and I'm still getting the valve noise.
Old Sep 10, 2014 | 06:34 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Not sure about this, but have you readjusted the valves since the install? 5k is about where that should be done,,,, I think..
Old Sep 10, 2014 | 08:56 PM
amkaos's Avatar
amkaos
i have gear drive cams.. they sound like sewing machine to me
Old Sep 11, 2014 | 12:11 AM
Juiced_deuce's Avatar
Juiced_deuce
VI, under light to mid accel while in too high a gear i have the same pinging, only when i am in too high a gear, i took it back to shop to recheck valves etc last week. builder told me its normal with cams, built up motor. it doesnt change with high octane or a booster added either.
i know i dont care for it but im not sure what can be done for it either. next spring i may go back to my dyno guy and have him ride and check it out and maybe change cams. i have the se211 now but i dont recall it when i had the se203s
Old Sep 11, 2014 | 04:26 AM
Village Idiot™
I just don't remember hearing the noise previous to the past week or so. I could be wrong though.
But! I think something may be loose. It sound like a thin piece of metal vibrating on other metal, almost like my gas gap rattle, but slightly more substantial. I was coasting in town with the clutch in on the way home from my girl's place last night and when I would hit a substantial bump, I heard the noise just once each time I hit the bump. So I'm thinking that 3K rpm may be the sweet spot for something that's loose to vibrate. I put the coil relocation kit on just a few weeks ago an with the extra wires and zip ties, something may be vibrating against something else or something may be loose. I have a wedding to shoot this weekend, so I probably won't get to it then, but I'm hoping to have time to go over it and check everything to see if I can't pin point the issue.
