Kuryakyn Road Thunder Sound Bar by MTX
Details Peak music power 300 watts. Two 2in. x 3in. full-range speakers with dual-voice coil. Four 1in. silk dome tweeters with N42 grade magnets for higher power handling. Amplifier 4 x 19WRMS, Max 4 x 23W. Integrated 3.0 Bluetooth receiver with automatic pairing via NFC. Integrated, water-resistant 1.0 Amp USB charging port in end cap. Auxiliary 3.5mm input in end cap for connecting devices via cable. Auxiliary 3.5mm output in end cap for connecting an external amp or additional sound bar. Speaker dimensions: 10.6in. L x 2.9in. diameter; bracket measures 6in. L x 3in. in diameter. Universal articulating mounting clamps fit handlebars between 7/8in. and 1 1/4in.; brackets are patent pending. Power, ground, ignition wire with connector for easy disconnect. All weather construction for use on any vehicle - weather-resistant in accordance with IP66 rating. Built-in, self-protection circuit and heat sink.
