Easy Brackets
Old Oct 5, 2012 | 05:16 PM
TheMo's Avatar
TheMo
Default Easy Brackets
Easy Brackets very lightly used and in great shape with all hardware and mounts for a detachable backrest. Mounts for fixed backrest or no backrest are available online.
$100 shipped!
ST-R1DB Bracket info:
  • This model is used on all Softail Models except the 2006 & later FXST, FXSTB and FXSTS, 2007 & later FLSTF (see ST-R2DB) & 2007 FXSTC (see ST-R3HB)
  • For use with small and medium sized saddlebags with a Quick Release Backrest
  • The docking posts attach to the front two mounting holes in the fender rail. (6 1/4" apart)
  • This is the same bracket as the ST-R1 but comes with different hardware for detachable backrests
  • Will not work on Softail Deluxe, use ST-L1DB Bracket instead.
Fitment information for your bike can be found on www.easybrackets.com or www.foxcreekleather.com .
Old Oct 8, 2012 | 07:36 PM
TheMo's Avatar
TheMo
Price drop bump!
Old Oct 12, 2012 | 07:44 AM
TheMo's Avatar
TheMo
Back to the top with new lowered price!
Old Oct 16, 2012 | 05:52 PM
dojodragon's Avatar
dojodragon
Will they fit a Deuce, do you have the part number?
Old Oct 16, 2012 | 06:04 PM
TheMo's Avatar
TheMo
part number is ST-R1DB (the DB means detachable backrest. All that means is the hardware. You can get non-detachable hardware easy enough if you need it)
Deuce is FXSTD correct? Might depend on the year.
From easybrackets.com:
ST-R1
all model years except 2006 & Later
FXST, FXSTB, FXSTS 2007 FLSTF & 2007 FXSTC This model is used on all softail models except the 2006 & later FXST, FXSTB and FXSTS, 2007 & later FLSTF (see ST-R2) & 2007 FXSTC (see ST-R3HB). The docking posts attach to the front two mounting holes in the fender rail. (6 ź “ apart) May only be used with small to medium saddlebags to avoid relocation of turn signals. If turn signals are to be relocated see ST-L1
Old Oct 16, 2012 | 07:45 PM
dojodragon's Avatar
dojodragon
Thanks for the reply, I am currently trying to resurch if your brackets will fit my bike. I think I will have to call easy brackets tomorrow and get the answer. How low are you willing to go on the price?
Old Oct 16, 2012 | 07:57 PM
TheMo's Avatar
TheMo
Let's make it $100 shipped.
Old Oct 19, 2012 | 08:07 AM
TheMo's Avatar
TheMo
Still for sale! $100 shipped - you can't lose!
Old Oct 28, 2012 | 12:50 PM
TheMo's Avatar
TheMo
Still available.
Old Oct 31, 2012 | 02:04 AM
Mouth's Avatar
Mouth
Hey If you still got em let me know!
