Possible Lifter Issue?
Old Oct 2, 2014 | 08:00 PM
Nikko78Shovel's Avatar
Nikko78Shovel
2nd Gear
Default Possible Lifter Issue?
Hey Y'all. Got a 95 sporty i picked up after it bit a buddy of mine. Fixed her all up road it all season problem free with a total investment of 1200 bucks. Its a 95 1200, unknown mileage. It appears however my luck has run out. Took it out the other day for a putt and didn't make it far before i heard what sounded like the popping of an exhaust leak, not continuous but when i stopped there was another noise, sounded like an air leak. As the bike sits at idle bothe noises go away briefly. My though at this point having checked exhaust and intake bolts and compression is that I have a sticky lifter that may not be allowing the valve to seal completely. Just wondering if anyone has had a similar issue or can lend any insight. I've been working on a 78 lowrider my whole life and the sporty engine is an animal I'm still learning. Thanks!
Nikko
Old Oct 3, 2014 | 07:21 AM
mrfikser's Avatar
mrfikser
I have never heard of the lifters sticking on these bikes, they do fail sometimes, and when they do they don't pump up and cause rocker arm noise.....maybe you have a bad head gasket that only leaks when its hot...other wise I got nothing...my next step after checking the intake and exhaust real good would be to start pulling the heads apart..
jackie18
Aug 4, 2018 07:12 PM
Royal Tango
2014-2024 Touring Models
May 1, 2014 08:27 AM
terrapin88
EVO
May 9, 2013 10:33 PM
TWGrimace
Mar 1, 2011 07:07 PM
dan conner
Exhaust System Topics
Nov 4, 2010 09:51 AM
