The 2007 Sporty, first year for fuel injection, is notorious for having corrosion issues in the fuse block/relay area caused by water intrusion. The problem will obviously be worse if the bike gets rained on frequently or sits outside vs in a garage. Corroded contacts can create all kinds of weird or intermittent problems.
To avoid problems, it's a good idea to remove all fuses and relays, clean the contacts, then coat the contacts with dielectric grease and reinstall. I would redo this every year.
You can get dielectric grease at any auto parts store.
thank you sir, unfortunately they're closed, so I'll just clean the fuses an relays for today. what is the best way to clean them?
