Primary / Trans fluid
Old Apr 2, 2015 | 12:01 PM
08fxdf43202's Avatar
08fxdf43202
Default Primary / Trans fluid
What type should I use.
It's been a long time since I had a Sporty... I've rebuilt a 98 1200S as a hard tail. It's time to add the fluids.
What do you all recommend? What about the crankcase?
Old Apr 2, 2015 | 12:59 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
for the engine try 25W-60 aviation. 20W-50 in the trans/primary
Old Apr 2, 2015 | 03:34 PM
Scuba10jdl's Avatar
Scuba10jdl
Old Apr 2, 2015 | 03:42 PM
cHarley's Avatar
cHarley
Originally Posted by Scuba10jdl
+1 - Mobil-1 75-90 Gear Oil in the primary/tranny and Mobil-1 15w50 in the motor.
100,000+ miles and still going........
Old Apr 2, 2015 | 05:43 PM
OddJack's Avatar
OddJack
This is what I use and recommend:
Red Line 42504 20W-50 Motorcycle Oil
Red Line 57904 75W90 Gear Oil (Primary)
Old Apr 2, 2015 | 06:36 PM
hexnut's Avatar
hexnut
This is what Dave from Red line says and recommends..
Thank you for contacting Red Line Oil, in the shared Sportster primary/transmission the 75W90 is recommended, a product that has been used extensively and performs well.
The 75W90 is the product we have have used for a number of years with very good results in Sportster/Buell transmissions, matching the viscosity and type fluid called for.
The 80W Motorcycle Gear Oil is a lower viscosity than called for, the ShockProof gear oils can due to their unique characteristics could cause sticking of the Harley clutches.
The 75W90 would be preferred and recommended over 80W Motorcycle Gear Oil in these applications.
There can be issues with some GL-5 gear oils in certain applications. Some can be corrosive to brass, bronze or copper, not an issue with our GL-5 gear oils, they don’t cause corrosion, pitting or metal removal. In a synchro equipped transmission the friction modifiers contained in many gear oils can make them too slippery, though not the case in a motorcycle transmission with dog rings.
So if you want the right viscosity and dont want to worry about it damaging anything, go with Redline http://www.redlineoil.com/product.aspx?pid=133&pcid=4
ken98k
EVO
25
Jul 4, 2018 12:37 PM
13RoadKing
33
Apr 10, 2017 03:43 PM
por2gezo
Apr 25, 2013 09:33 AM
tomtek
Oct 19, 2010 06:36 PM
01heritage
Apr 20, 2009 10:05 AM
