battery question
Old Apr 3, 2015 | 10:41 PM
harley7316's Avatar
harley7316
Default battery question
Hi was wondering bought a replacement battery and the posts are not flush with the side of the battery.I need a little spacers do they have to be lead spacers?Also the bolts will be to short with spacers can i just use a regular steel bolt?Thanks
Old Apr 4, 2015 | 09:27 AM
mopeman-72HD's Avatar
mopeman-72HD
The new battery didn't come with a little bag of bolts and spacers?
Old Apr 4, 2015 | 09:36 AM
o0smitters0o's Avatar
o0smitters0o
Did you buy a Harley battery or aftermarket. I hate those little square ding bobs you have to put in the hold just right with small screw driver. It should have 2 square pieces that fit in terminal then to small tubes to shim it out. Depending on manufacturers. I go with HD now the threads are in the terminals. I got burnt by this also with well known distributor.
Old Apr 4, 2015 | 09:44 AM
o0smitters0o
I have a bunch of different ones some silver looking not lead and brass looking ones. It should work just make sure nothing is going to arc. I would call who ever you bought it from. I bet they have no problem sending you that bag of parts that should of come with it. Most companies are good about that, simple mistake. They may even over night it. If it's conductible it will work just try to get the right parts coming. Mean while ACE is the place or if you have an Indy shop they probably have tons in plate on a shelf and love to help.
Old Apr 4, 2015 | 09:46 AM
SIDECAR BOB's Avatar
SIDECAR BOB
usually they are brass spacers but any metal spacer would word, believe the bolts are metric but other than that yes any bolts will work that are the correct thread
Old Apr 4, 2015 | 09:49 AM
o0smitters0o
Sorry last reply some terminal screws have one of those pointy washers so it will lock in place. Worst thing could happen is it will start you'll ride off never come home.
Old Apr 4, 2015 | 11:49 AM
harley7316's Avatar
harley7316
its a interstate battery came with bolts and those square nuts in a sealed bag but no spacers.looks to me if i use spacers the bolts will be to short
Old Apr 5, 2015 | 10:38 AM
ib5150's Avatar
ib5150
Get ready to install another battery in about 5 months, my battery went out when I was on the road and the only place around was a Honda dealer so I bought the Interstate battery they said had the proper cranking power and it lasted about 5 month before it took a ****
Old Apr 5, 2015 | 11:45 AM
harley7316's Avatar
harley7316
what do recommend for a battery?I have used interstate in my vehicles before and never had a problem?Harley battery is way to much and i am pretty sure harley doesnt make there on batteries
Old Apr 5, 2015 | 12:22 PM
ThePaintPirate's Avatar
ThePaintPirate
I know there's a semi-cult following towards dry cell batteries. More expensive but last for many years.
Blk80bike
Sep 20, 2016 11:48 AM
jwyrem
May 9, 2011 09:03 PM
jbt
Aug 30, 2007 10:26 PM
HTRAUD
Apr 22, 2007 10:52 PM
stevegray
Sep 16, 2006 01:56 PM
