Indicator Help
Old Apr 13, 2015 | 09:40 AM
FLaVaZ's Avatar
FLaVaZ
Default Indicator Help
Was looking to purchase these on Amazon -
Amazon.com: 4x 39mm Motorcycle LED Turn Signal Indicator Light For Harley Bullet Smoke Clear: Automotive Amazon.com: 4x 39mm Motorcycle LED Turn Signal Indicator Light For Harley Bullet Smoke Clear: Automotive
My question is, do you think these are plug and play or do I need to splice wires/install a relay of some sort? Seems like a good set for the money.
Thanks,
Vinny
Old Apr 14, 2015 | 11:38 AM
FLaVaZ's Avatar
FLaVaZ
*bump*
Old Apr 14, 2015 | 01:33 PM
grbrown's Avatar
grbrown
They make no mention of including any sort of ballast. LEDs have much lower current draw than normal bulbs, so your stock flasher unit may not work (mine doesn't with the LED flashers I have). That requires either the addition of a ballast unit, to fool your stock flasher unit into working, or replacing your stock flasher unit with an LED friendly one. I use a Badlands, which will add greatly to the total cost.
SteddyTeddy
EVO
Jan 23, 2019 09:17 AM
96slowbra
Electrical/Lighting/Alarm
Nov 18, 2015 10:17 AM
harley012
Aug 4, 2013 10:59 AM
griggi63
May 31, 2011 10:54 PM
98glider
Ironhead
Dec 21, 2008 07:04 PM
