Electrical problem
Old Jun 17, 2015 | 06:47 PM
Slimlou29's Avatar
Slimlou29
Stage II
Question Electrical problem
Hello, I have a 2005 Sportster 1200c. I am having spotty electrical issues. I have always had electrical issues with this bike going through batteries once a year. The first real issue I had was about a year and a half ago when I bought a cheap battery that had a very small terminal and I melted the terminal to nothing. I still can't figure out why it did that. Recently I when to start my bike and heard a click when I engaged the starter and the lights and everything went dead. I messed around with the battery cables and got the bike to light up again and then it was able to turn over. I ended up not riding to work because I didn't want to have that issue at work. When I got home I decided to tackle the issue and took the battery out and looked at all the cables to see if they were corroded. I could not find anything that needed anything more than a wire brush. I now can't get headlight on the bike to turn on or give me any signs that it is hooked up to the battery. I tested the battery and it was fine. I am now debating weather or not to take it into HD because I am out of solutions. I can hold my own mechanically, but when it comes to electrical I am up the creek. I did stumble into one thing that I think is a problem. I know the bike should be grounded but I am getting positive feel off of the bike. I checked this by hooking up the battery cables and touching my LED lights to different parts of the bike and they turn on... I don't know if thats normal or if I have a positive wire touching the frame at some point causing it to ground out. Before I spend the money to have it looked at I didn't know if anyone had any diagnostic tests or solutions that could be of help. Thanks for reading.
Old Jun 18, 2015 | 06:13 AM
Thumper26's Avatar
Thumper26
Sounds to me like you are getting intermittent ground continuity. You need to disconnect the battery's ground cable from the engine. Clean the cable end with a wire brush and sandpaper, coat with dielectric grease, and reattach. Actually, doing this on all cable ends would be a good idea.
Old Jun 20, 2015 | 08:33 PM
Slimlou29's Avatar
Slimlou29
Stage II
Thanks. I did that and soldered the cable ends and it's back on the road. Thanks for the advice.
firemouth
Electrical/Lighting/Alarm
Jun 21, 2016 04:43 PM
dondeez
Nov 3, 2013 09:18 PM
aahmes57
Jun 12, 2012 06:35 PM
bykeguy
Mar 19, 2008 06:31 AM
bobbsterkid7
Oct 8, 2007 01:21 PM
