Tire plug opinions
Old Jun 24, 2015 | 09:29 AM
CipoWins42's Avatar
CipoWins42
Originally Posted by 06FXDLI
That's my dilemma. I've always patched and plugged tires, my whole life.
This was the first time I have ever heard that it's not safe to do so.
You'll read a lot of things on here that you'll never read or hear about anywhere else.
Old Jun 24, 2015 | 12:02 PM
Rollbar's Avatar
Rollbar
Originally Posted by Mr_Taipan
If you remove the tyre you can check the tyre bands which form the construction of the tyre. If the nail has cut through one of those I may not use it, but if it hasn't I'd put a mushroom patch in it.
I've plugged loads of tyres and I too have never had one fail. I use the stop n go plugs and then if I bother to remove the tyre I use a mushroom patch glued to the inside.
Never have heard about this product-looks easy to install etc.
Found it at J&P and Amazon - http://www.jpcycles.com/stop-and-go?...=c&matchtype=b
Thanks,
P.S. I installed Ride-on tire sealant/balancer stuff, works pretty good and I'm sure it would work well w/a plug to seal etc.
http://www.ride-on.com/motorcycle-formula-mot.html
Old Jun 24, 2015 | 12:06 PM
Rollbar's Avatar
Rollbar
Originally Posted by Rog48
Ive been using plugs on anything of mine that has tires since the early 80s. Ive yet to have a failure.
Question, do you use the old style plug/straw push-in type?
Old Jun 24, 2015 | 03:47 PM
16FXDLI's Avatar
16FXDLI
Update
Ok, I felt very guilty about doing the plug. My 16 y/o is the primary rider on this bike. His safety is more important to me than the price of a new tire.
Bike is at dealer getting a new tire.
Old Jun 24, 2015 | 04:18 PM
Rollbar's Avatar
Rollbar
Update
Don't feel guilty-I would do the same thing for my child.
What tire are you getting/MFG?
I hope not the Dunlop-Mine slip on tar snakes and some cornering/doesn't stick well-Just a thought.
Old Jun 24, 2015 | 04:22 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I don't trust a patch in a motorcycle tire. You only have two tires. Just my opinion.
Old Jun 24, 2015 | 04:28 PM
Rog48's Avatar
Rog48
Update
The tire manufactures marketing has worked
About half the people on this thread say its bad news, yet not a single instance of it actually being bad news.
Kinda like changing your oil at 3K miles, if it makes you feel beter.....go for it.........not really doing anything though.
Old Jun 24, 2015 | 04:39 PM
Rog48's Avatar
Rog48
Dont know what the straw kind is. They are some kind of rubber impregnated nylon I think. You thread it through what looks like a big needle, after prepping and glue you push it through the hole and back out. You end up with it folded over 4 times. I then cut it off flush.
Ive never had one fail or affect the tire that I could tell. The oldest I have is on my ridding mower, yeah I know it only a mower. But I picked up a screw about a month after I bought it, plugged it, still working almost 26 years later.
All other plugs Ive used lasted till I needed new tires or sold the vehicle.
Old Jun 24, 2015 | 05:08 PM
Mr_Taipan's Avatar
Mr_Taipan
Thanks,
Its a very good product but can be awkward to use until you get the hang of it. I had a few failed attempts when I first used the kit and found the trick to be make sure you ream out the hole well first. Actually worth practising if you have an old wheel and tyre laying around. I put extra lithium grease (chain wax) in with the plugs which really helps.
The plugs are little mushroom types (see pic below) but are only held in by air pressure. That said they work and work well if fitted correctly. I think my father-in-law has about 3 or more in each of his mower tyres! Also got us out of trouble when we picked up a puncture in the back of nowhere in France and found the spare was flat!!
Old Jun 25, 2015 | 12:00 PM
mrfikser's Avatar
mrfikser
the tire sellers say they are not safe and I am sure they are not- as safe as a new tire...but on the rear of a bike in the center of the tread I would not worry about having a plug in the tire...I have been riding motorcycles for going on 50 years and around garages that do repairs for the same length of time and have never seen a plug cause any issues except for coming out once and leaking a few times...
