Need help- jagg Oil cooler install problem
Old Jun 27, 2015 | 10:02 AM
WVDevil's Avatar
WVDevil
Exclamation Need help- jagg Oil cooler install problem
So, installed this this exactly per instructions. Everything went fine but now oil filter will not go on. Best I can determine its hitting the motor mount.
Ideas? This thing was supposed to be a direct fit.
Old Jun 27, 2015 | 11:11 AM
elfnyc's Avatar
elfnyc
i see it says
Some Sportster models may require rotating the mounting of the 4700 offset oil filter adapter 180 degrees, placing the hoses above the filter In these
installations, the anti-rotation device is not required, and you may now skip to step 16.
thats from the website
Old Jun 27, 2015 | 11:48 AM
WVDevil's Avatar
WVDevil
Originally Posted by elfnyc
i see it says
In the end this is the answer. It would be cool if the instructions made some mention of WHY some Sportster require that orientation. Oh well, its on now.
Old Jun 27, 2015 | 01:12 PM
elfnyc's Avatar
elfnyc
sweet - so u did have to rotate it ? anyways get some pix of the entire setup , i just might get one in the near future would like to see how it loooks
Old Jun 27, 2015 | 02:13 PM
lewk's Avatar
lewk
Oil cooler ehh... I see...
What next, surround sound and air con?
Old Jun 28, 2015 | 08:41 AM
WVDevil's Avatar
WVDevil
A/C is built in
firehawk6
Jun 22, 2018 07:11 PM
cudacrazy73
Oil Archive (no new posts)
Jan 16, 2017 09:35 AM
doublenaughtspy
Aug 8, 2008 06:05 AM
kingultra
Aug 9, 2007 10:15 AM
Joker441
Mar 27, 2006 02:57 PM
