are arlen ness a/c compatible with s&s carbs?
Old Jul 18, 2015 | 12:43 PM
j_sporty's Avatar
j_sporty
4th Gear
Question are arlen ness a/c compatible with s&s carbs?
i have a 01 1200 custom. i want to put an s&s carb and thinking of going with a arlen ness air cleaner just cant find if they are compatible or if theres adapters that i can install to make work. any info would help thanks.
Old Jul 18, 2015 | 04:05 PM
j_sporty's Avatar
j_sporty
4th Gear
reached out to j&p cycles tech will not work meant only for oem carb... gas mileage is pretty low as is so might just keep original carb.
Old Jul 18, 2015 | 04:27 PM
grbrown's Avatar
grbrown
Most aftermarket brands only make stuff to fit stock Harley stuff, not other aftermarket brands. Of course the challenge is to make such mixed up things work, if you are up to that! Of course there is only one filter that looks right on an S&S carb - theirs!
Old Jul 18, 2015 | 04:48 PM
j_sporty's Avatar
j_sporty
4th Gear
yeah i get what youre saying just the tear drop cleaner i see every where and im going for a different look for my bike. but thanks
Old Jul 19, 2015 | 04:03 AM
grbrown's Avatar
grbrown
I was teasin', but S&S does have other styles of filter now. It may be possible to modify the one you mention, may even be worth contacting Arlen Ness direct, to see if they can offer any tips.
Old Jul 19, 2015 | 08:00 PM
John Seagroves's Avatar
John Seagroves
You "may" have to buy an S&S intake manifold also. The stock HD cv carb is slip on where as the S&S is bolt on. If you're going with S&S; get their air cleaners. It will make life a lot more easier and you won't bust a blood vessel like I did. I wanted to put on the Arlen Ness stage two air cleaner and had to return it to J&P cycles. If I would have known, I would have just bought the S&S kit, and not each individual piece.
cimnut
EVO
16
Nov 2, 2016 07:15 PM
CSS_FXD
Aug 17, 2014 01:56 AM
nazareth27
Mar 24, 2008 03:37 PM
cwilks
Apr 3, 2007 09:26 PM
FBFletch
Exhaust System Topics
Mar 30, 2006 11:08 AM
