nightster backfiring stalling
Old Jul 30, 2015 | 10:49 PM
Sevenunder29's Avatar
Sevenunder29
4th Gear
Default nightster backfiring stalling
2008 EFI nightster. Wife had it for several years. NEVER had any performance issues. Always kept in unheated garage during winter (PA). First startup of year...ALWAYS fires right up with no hesitation and runs great (Ive been jealous...I have 2000 ntrain...its a BEAR to get going in spring). This spring...no exception...Nightster ran great....as usual.
2nd run of spring....I get gas for it (wife let it sit over winter with almost no gas). 10 minutes after I put gas in tank during 2nd run.....backfiring, sputtering, missing, etc. I barely made it home. Put new plugs in it, drained all gas, put new gas in (from different gas station) in it WITH fuel injector cleaner. Took it out....ran fine for 3 mins....then same thing happened. I had to push it back 1.5 miles to house.
Now...put new fuel filter in it. Same results....sputter, backfire, missing, stalls.
Any suggestions?
Note: This past winter....temps were at -26deg F. Not sure if that effected the bike. It ran great for first run with no signs of trouble.
Havent replaced Fuel Pressure Regulator or Fuel Pump Assembly.
Need help.
Old Jul 31, 2015 | 03:53 AM
Mr_Taipan's Avatar
Mr_Taipan
If you've done that many fuel changes then I'd try looking at some obvious things, like electrical connections, especially as its back firing. When it was doing this was your speedo behaving erratically?
Try removing the main fuse and clean up the terminals. Then disconnect and clean cleaning up battery terminals and at the other end of both leads. The earth point on the frame on the left side looks a bit exposed, so that's deffo worth a clean up and use some dielectric grease when bolting back up.
Even if it isn't this, its still a good thing to do anyway and wont be wasted time.
AwhiteheadA
Jun 19, 2018 05:45 PM
HD Jim
Sep 25, 2013 05:24 PM
usarmyharley
Sep 27, 2012 07:55 PM
speakerfritz
Mar 14, 2012 09:10 PM
pmedic433
Sep 13, 2011 05:36 PM
