any one try the tank seal kits?
Old Aug 6, 2015 | 08:14 PM
joshlewis33's Avatar
joshlewis33
Default any one try the tank seal kits?
My tank has what looks like old paint chips floating around in it so i took the tank off pulled the petcock and cleaned it out tried flushing it with water and still have crap rolling in there i was thinking maybe compressed air any tips would be great thanks! Then was thinking trying the seal kit..
Old Aug 7, 2015 | 05:36 AM
Rog48's Avatar
Rog48
Marbles, ball bearings or steel shot. Put em in shack it up.
Old Aug 7, 2015 | 04:58 PM
holli4pirating's Avatar
holli4pirating
5th Gear
I used the gas tank sealer from Caswell on a Paughco tank. Prepped it by putting in some mineral spirits and drywall screws and giving it a good shaking. That was what the kit recommended, and it seems to have worked great.
Old Aug 7, 2015 | 06:04 PM
artc's Avatar
artc
I got a tank doing the same thing. Tried cleaning it out with water, air paint thinner and acetone. Still peeling off.
Guy online said don't worry, the stuff will not pass thought the fuel stainer.
Guess what, he is right.
No problems with the flakes just don't look in the tank.
Old Aug 7, 2015 | 07:15 PM
NO-TATTOO's Avatar
NO-TATTOO
you may want to look into some stuff called Por-15. I have used it before with great results
Old Aug 10, 2015 | 03:14 PM
Rob Robb's Avatar
Rob Robb
Don't use Kreem sealer!
I had it in my Softail for years then it reacted with something in the gas and turned back to a glue like substance, Clogged up filter, fuel lines & carb.
I eventually had to replace the tanks because I couldn't get it all out. Flushed & cleaned filter, fuel lines & rebuilt/cleaned carb.
I don't use any sealer now. Just keep the tank full of fuel with stabuil 360 added during Winter to prevent rust
skooter2000fb
Carburetor Related
Jan 30, 2013 02:48 PM
red69camaro
Jun 21, 2011 06:37 PM
jtmurph00
Sep 16, 2009 09:05 PM
GothMetalGuitarist
Feb 1, 2008 01:07 PM
Bill918
Nov 12, 2007 12:48 PM
