Help with dtc codes
Old Aug 24, 2015 | 07:55 AM
Antanooch's Avatar
Antanooch
2nd Gear
Default Help with dtc codes
My 04 sportster 1200 shows me bus err in the speedo check engine light comes on and red key light comes on but then goes off and normally when in neutral and at idle it will come back what is it has anyone ever had this before and if so what are some things to look into! Thanks to all in advance
Old Aug 24, 2015 | 08:39 AM
cHarley's Avatar
cHarley
There's a "How to DTC" Sticky thread at the top of this section, have you followed the instructions?
Old Aug 24, 2015 | 10:00 AM
Antanooch's Avatar
Antanooch
2nd Gear
I have not tried it I am pretty sure on how to go through it but was also wondering what bus err meant
Old Aug 24, 2015 | 11:37 AM
cHarley's Avatar
cHarley
"bus err" indicates a problem (error) on the serial data buss which is the communication path between the ICM/ECM and other modules like speedo, TCM, etc.
Old Aug 24, 2015 | 12:21 PM
Antanooch's Avatar
Antanooch
2nd Gear
Could that be caused from changing out lights! I new to Harley so a lot of it is foreign to me
Valleyofthegun
Electrical/Lighting/Alarm
Sep 25, 2018 11:16 AM
mrhammer2u
Sep 19, 2017 01:30 PM
schwingding
Sep 15, 2011 06:26 AM
luckydawg110609
Mar 14, 2011 01:35 PM
virtualmike13
Oct 14, 2007 03:47 PM
