Lock tight
Old Nov 7, 2015 | 01:24 PM
HarleyScuba's Avatar
HarleyScuba
...on the screw holding my seat...
I use the purple, low-strength Loctite for the rear seat bolt, because I frequently change saddles. You don't want to need too much force to loosen that bolt, or the hole in the fender and/or the nut gets boogered. There's a notch in the fender hole that keeps the nut from spinning. I've also encountered having the nut break in two, before I started using the purple.
Old Nov 7, 2015 | 01:33 PM
ShovelEd's Avatar
ShovelEd
Oooold joke:
The reason Harleys have saddlebags is so you can carry the parts back home when they fall off.
Blue Loctite is (my)your best-ist buddy.
Old Nov 7, 2015 | 01:39 PM
grbrown's Avatar
grbrown
Red face
Originally Posted by grbrown
I'll be buying Loctite blue pdq!
Which I've just done and discovered that it rather confusingly comes in a red bottle! It does have a small blue flash on it and mine is Loctite 243, for future reference. I've thrown away the Brand X stuff I was using.
Old Nov 7, 2015 | 03:01 PM
ylwf3vr's Avatar
ylwf3vr
Hm.. I may have to do the same...
Old Nov 7, 2015 | 04:29 PM
tloc1000's Avatar
tloc1000
How do you get it off the bolts you're taking off? I've messed up the thread on some bolts that has some old loctight still on them.
Old Nov 7, 2015 | 04:33 PM
2500hdon37s's Avatar
2500hdon37s
wire brush.
and you can buy thread chasers for the hole the bolt goes in, but I've never had a problem with bolt or hole damage after just knocking the loctite off the threads of the bolt.
But if you're having trouble removing the bolts; You're either using way too much loctite, over tightening things, or using the wrong strength, shitty tools, or need some heat. Loctite can be "uncured" once heated to 500*F
Old Nov 7, 2015 | 04:34 PM
ylwf3vr's Avatar
ylwf3vr
I would imagine you can take like hair dryer or something to them no?
Old Nov 7, 2015 | 04:39 PM
HardRider1's Avatar
HardRider1
Loctite = Harley Glue
Old Nov 7, 2015 | 05:46 PM
grbrown's Avatar
grbrown
Wink
Wire brush! Make a point of using a Loctite that is intended for easy disassembly, such as the 243 I have just bought.
Old Nov 7, 2015 | 10:30 PM
Dane M's Avatar
Dane M
Blue seems safe to put on everything. Red is REALLY gnarly. You will find this out quickly if you ever use red on something and then need to get it off later, that ****'s intense.
