883 ignition problem
Old May 9, 2007 | 07:35 PM
gtreasur's Avatar
gtreasur
Stage III
Default 883 ignition problem
For everyone,
This winter i painted my 2005 883 sportster and put new bars, hand controls, pipes and an internal throttle on it, i just got it back together and can't get it to start. It is turning over but that's it, not even a sputter or cough. I'm not a mechanic, so i'm not sure what it may be. The carb is getting gas, the plugs are good and sparking and the fuses are good. When i wired up the hand controls i had a wire touching off the inside of the button housing and i blew about 6 fuses before i tracked it down. i've read that the ignition modules are virtually indistructable, could i have damaged the control modules, coil or one of the sensors while blowing the fuses? My harley dealership says thay can't test the module without bringing the bike in, that would be a little hard sinse it is in my shed and not starting. Does anyone have any ideas what the problem could be?
Old May 9, 2007 | 07:59 PM
Zimbob's Avatar
Zimbob
Default RE: 883 ignition problem
You might want to re-trace everything you did. Most likely, there is a cut wire somewhere, or one that got overlooked. Elect. problems suck !! They can take lots of time to find, and make you loose alot of hair too. If you can't find the caues, I hate to say it, but it might need to go to the dealer. unless you know a tech that will come out to your place and help.
micathia
Nov 16, 2018 03:39 AM
Felix the cat
Oct 10, 2013 11:41 PM
MissouriRidgeRunner
Jul 28, 2011 07:43 PM
Erikh425
Ironhead
Jul 17, 2011 03:07 AM
87XLH1100
Aug 31, 2010 04:01 PM
