2016 Exhausts
Old Jan 19, 2016 | 04:47 AM
BensonUK's Avatar
BensonUK
Default 2016 Exhausts
I think the answer is yes but I am trying to confirm if an exhaust from a 1026 Iron will fit on a 2015 Iron.
Just been offered a set of take offs from a 2016 and thought the full black system will look pretty sweet on the girlfriends Iron.
Just need to know if anyone has any clue
thanks
Old Jan 19, 2016 | 09:52 AM
grbrown's Avatar
grbrown
Wink
As another member put it recently, teach a member to fiche and he will never go hungry! You can check part numbers on-line here and read across to other model years. The parts numbers for both years are identical.
Old Jan 19, 2016 | 10:17 AM
cvaria's Avatar
cvaria
^this^
and you can use older exhausts, you'll just need to swap the older header pipes. add 30 more minutes to your install.
see here:
https://www.hdforums.com/forum/sport...83-iron-3.html
Baja38ss
Audio Systems
Apr 28, 2016 08:23 PM
Yellie74
Welcome Area Only
21
Feb 24, 2016 09:35 PM
riteway
Good Or Bad Shopping Experiences At HDF
Jan 14, 2013 04:37 PM
Sash302
Jun 21, 2009 06:24 AM
joromu
The General Motorcycle Forum
Feb 25, 2009 09:02 AM
