Help with engine codes
Old May 10, 2016 | 07:30 PM
Peedib89's Avatar
Peedib89
Default Help with engine codes
I have a 2008 nightster that just started throwing a P0118 and P0132 code, can anybody tell me if these are standard codes or if there is an easy fix? I looked up the codes and P0118 is ET Sensor Voltage Open/High EFI and P0132 is front oxygen sensor high. I have the black screamin eagle slip-ons on the bike could that be the cause?
Old May 10, 2016 | 11:02 PM
elfnyc's Avatar
elfnyc
check the terminal on the ecm make sure everything is snug and not cut ,lose,or corroded
Clear the code/codes
Start up and let idle. did the Codes reapeaT? simple things first.
Old May 11, 2016 | 04:50 AM
grbrown's Avatar
grbrown
You should find a key to those codes in one of the Tech section Stickies.
emperor wurm
Oct 21, 2015 01:05 PM
joe mayo
Mar 19, 2012 08:47 AM
JohnFlorida
EVO
Apr 13, 2011 06:15 AM
nkauf21
Aug 15, 2010 04:08 PM
shoveltrev
Exhaust System Topics
May 27, 2008 09:34 PM
