Drag Bars
Old May 20, 2007 | 10:39 PM
FlyinJ's Avatar
FlyinJ
Default Drag Bars
Want to add drag bars to a 06 883 Custom. Is there enough clearance so that the turn lights clear the tank, and where is a good place to order.
What length, cables okay and any other good info. I might need to know before getting them.
Thanks in advance.
Old May 21, 2007 | 04:51 PM
128auto's Avatar
128auto
Default RE: Drag Bars
I have seen people adding drag bar on 06 883C and leave the turn signal same location, no problem at all.
Here is one.
Old May 21, 2007 | 08:59 PM
Captain Morgan's Avatar
Captain Morgan
I just put them on my 07 xl1200c. No big issues, but i did adjust the blinkers a little bit to clear the tank for sharp corners. If all else fails, you can buy the relocation kit, or check out 128auto's write up of his DIY relocation. As far as cables and such, you should be fine.
3bc
Nov 16, 2014 07:37 AM
Jimmy The Kid
Aug 7, 2012 03:52 PM
Mlake
Aug 8, 2010 11:37 PM
scottl23
Jul 12, 2006 01:56 AM
eg2sol
May 13, 2006 11:07 PM
