Pulley swap
Old Apr 3, 2019 | 02:30 PM
TStephen's Avatar
TStephen
Originally Posted by apache snow
It may be for some but not for me. I did it the same time I changed out my clutch. I doesn't affect the speedometer either. I say what ever works best for you.
The OP wanted to know about dropping the RPMs at cruising speed. He now has all the options.
I stand corrected.
I started off thinking about drive belt pulleys and never considered swapping out the primary pulley, clutch shell, and a longer primary chain.
Thank you for the schooling.
Not something I would do, but if it lights your fuse, why not?
Old Apr 3, 2019 | 03:36 PM
apache snow's Avatar
apache snow
That's the way a 1200 is geared. When I did my 1250 kit I wanted the same gearing as a 1200 would have. The 883 uses a 34 tooth primary sprocket and the 1200 uses a 38 tooth sprocket. It seemed to me the right way to do it even if its a little more work.. I was going to be in the primary housing any way putting in a Barnett clutch. I have all the tools needed to do the job. So it wasn't that big of a deal. The speedo gets its info from the transmission so what gets changed before the trans wont throw it out of calibration. If you change the final drive pullys it throws off the speedo calibration. . Still not a big deal I guess but that's just me. I just got back riding the bike. When it was an 883 it would be turning 4000 rpm at 70 mph. Now it turns 3400 rpm at 70. That is a good reduction and makes cruising easier to me.
Sorry for any misunderstanding.
Old Apr 3, 2019 | 03:45 PM
Packgrog's Avatar
Packgrog
That right there is a good example of one of the side benefits I was asking about. Good info there.
Old Apr 3, 2019 | 09:03 PM
WKNDS's Avatar
WKNDS
hexnut! I just now made the connection...
Sorry for going off-topic.
T.
Old Apr 4, 2019 | 06:50 AM
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by screaminfast
I feel like changing the primary sprockets is so much more work than just changing the belt pulleys no?
That's quite true. Unfortunately both have limited options which restricts what we can do, unless we change to chain rear drive, for which there are more alternative sprockets, front and rear.
Old Apr 4, 2019 | 08:43 AM
NPV288's Avatar
NPV288
I have looked into this a lot and have found that changing the belt sprockets is the easiest solution. Either a chain conversion or buy the sprockets from 883Sportster.com
Messing with the primary is a whole nother gig, if you understand how it works then go for it! For the weekend handy man swapping the external sprockets is the best solution.
Old Apr 4, 2019 | 10:20 AM
TStephen's Avatar
TStephen
Originally Posted by NPV288
I have looked into this a lot and have found that changing the belt sprockets is the easiest solution for me. Either to a chain conversion or from 883Sportster.com
Messing with the primary is a whole nother gig, if you understand how it works then go for it! But for the weekend handy man swapping the external sprockets is the best solution.
I agree, and if you are like me, you don't have to worry about the speedometer being off, because I don't have a speedo anyway.
*** I use Ulysse Speedometer Pro to track my MPH to avoid tickets, and it keeps track of my mileage while offering maps of my rides.
Old Apr 4, 2019 | 11:21 AM
NPV288's Avatar
NPV288
You can even get the speedo module to fix the speed or just do the math and know you are off by 5MPH at 60 or 7 MPH at 80.
Old Apr 4, 2019 | 03:26 PM
TStephen's Avatar
TStephen
My bike seems to be missing that module.
Old Apr 5, 2019 | 09:36 AM
Packgrog's Avatar
Packgrog
Hadn't known about apps like this. Pity the iOS speedo apps aren't as detailed as the one you shared. Also a pity that nobody has a split-screen app for GPS and speedometer. That would be very slick.
I still haven't seen anyone share any experience about what a lower mass final drive pulley might do for your, even keeping the size the same. I'm curious about the practical benefits of that. Better acceleration? Easier turning from the lower centrifugal force due to the lower mass? Or is the difference negligible apart from the drop in the bucket weight savings?
