Load Equalizer?
Old Sep 18, 2016 | 09:30 PM
itsmeduh's Avatar
itsmeduh
Stage I
Default Load Equalizer?
Hey all. New to the forum and LED lights and need a little help with some things. I recently installed a LED headlight and already had LED taillight. As soon as I turned the bike(it's a 2007 xl1200R)on, the brake light stopped working and I popped a fuse. My question is: do I need a load equalizer if I'm not doing LED turn signals?
Any help is much appreciated!
Old Sep 19, 2016 | 06:21 AM
grbrown's Avatar
grbrown
No, you don't need a load equalizer, that is to fool your flasher unit into thinking that it still has conventional bulbs in the indicator lights. If you popped a fuze that indicates there is either a wiring error, or possibly a damaged wire, may even be that there is a fault in the new tail-light.
Old Sep 19, 2016 | 07:03 AM
JayTee2015's Avatar
JayTee2015
Make sure you bought the correct LED replacement bulb for that tail/brake light. Some of those import LED bulbs have strange internal wiring.
Old Sep 24, 2016 | 12:57 PM
Davemac122383's Avatar
Davemac122383
I recently purchased a LED headlight and it kept popping the fuse. Returned it and got another one and all was good, no more fuse popping. There is a possibility that your new light is defective or a pinched wire/wiring issue.
Old Sep 25, 2016 | 08:42 AM
cvaria's Avatar
cvaria
i installed a cheap led h4 (not the dk h4) in my sportster and it immediately blew a fuse... i pulled the bulb out and threw it in the trash......
this...
http://www.ebay.com/itm/NEW-H4-Motor...item3d06f431fa
i swore off cheap leds after this.
load equalized had nothing to do with it... and i have one in there.
TheMurf
May 15, 2019 06:00 PM
Wray67
Electrical/Lighting/Alarm
Aug 27, 2015 11:43 PM
traildog
EVO
Jun 27, 2012 07:37 PM
Gra490
Nov 14, 2010 02:54 PM
09NightsterVB
Apr 28, 2010 10:57 PM
