Won't start.
Old Oct 19, 2016 | 07:39 PM
Greed's Avatar
Greed
Stage II
Default Won't start.
I have a 1993 Harley Davidson Sportster 1200 that will not start. I've checked the oil level changed the battery and the starter relay. Still no luck. I can hear the relay clicking but doesn't turn the starter over.
Anyone have a suggestion on what might be the problem. It sat up a couple of weeks and ran fine before that. Now it won't even turn over.
Any help would be appreciated.
Old Oct 19, 2016 | 07:51 PM
Browning, nb's Avatar
Browning, nb
welcome. Test and charge your battery. Clean the terminals and ground wire.
Old Oct 19, 2016 | 07:55 PM
RANGER73's Avatar
RANGER73
When I had this similar issue it was the little relay under the seat. It clicked but wasn't making contact internally. After the second one did the same thing I installed a push button on the starter, I also pulled the relay apart and "adjusted" the contacts. It hasn't given me a problem since.
Old Oct 19, 2016 | 08:48 PM
Greed's Avatar
Greed
Stage II
Thanks for the welcome and thanks for the help.
I'll try adjusting the relay. If there is anymore information please submit
Old Oct 20, 2016 | 09:33 PM
1st time HD owner's Avatar
1st time HD owner
try tapping the starter with a hammer.if that doesn't work u can also try to push start it/popstarting. you can also remove starter and have it tested by your local HD dealer.
Old Oct 20, 2016 | 10:05 PM
RedRanger7's Avatar
RedRanger7
Click that kill switch on the handlebars off and on a few times in case it is getting corroded inside. You said you changed the battery so it wouldnt be that loose neg battery terminal I had a problem with last year. Hope it fires up soon!
Old Jul 8, 2020 | 09:45 AM
Ryan Frantzen's Avatar
Ryan Frantzen
6th Gear
sech4787
Apr 10, 2018 05:24 PM
Chris1957
Engine Mechanical Topics
Apr 24, 2016 01:54 AM
Sporty69
Jul 29, 2012 08:15 AM
bcakesdevry
Aug 8, 2011 01:49 PM
Hombre Josh
Jul 22, 2010 12:35 PM
