weird tire thing
Old May 29, 2007 | 04:07 PM
LAZYBOY's Avatar
LAZYBOY
Default weird tire thing
twice i have gotten ready to ride only to find that my front tire is nearly flat. i always do a post ride check when i clean the bike. i check the tires before every ride. the first time i was able to ride to the station and air it up. i checked it all that day and it was fine. well, i did alot of rain riding since friday if it matters, and it happened againyesterday morning. it was totally flat. i have a tank now and aired it up and took a 75 mile ride.checked it againthis am and it was fine. rode about 75 miles again and still o k. i have a bell and this kind of stuff should not be happening. any ideas??
Old May 29, 2007 | 04:18 PM
sleepneagle's Avatar
sleepneagle
Default RE: weird tire thing
check your stem and valve for a slow leak. use a little detergent in some water to see if it will blow a bubble.
Old May 29, 2007 | 04:20 PM
MacAttack's Avatar
MacAttack
Check the valve in the tube - they sometimes leak; it's easy to replace. Squirt a bit ofvery soapy water in the valve and see if you get bubbles. Also, you might have a pinched tube if you were riding on it when it was really low - but I really think it's your valve. Do you have a cap over the valve?
Old May 29, 2007 | 04:29 PM
LAZYBOY's Avatar
LAZYBOY
got a cap. i did not check very well aroung the stem though. i was sitting on the bike rolling backward and squirting soapy water. i bet you guys are right. thank you. kinda looks like a new front tire is coming soon anyway
Old May 29, 2007 | 04:32 PM
128auto's Avatar
128auto
You have a laced wheel w/tube, correct? I can't think of anything beside checking the valve stem area, if the tube leaks, it usually leaks very fast.
Old May 29, 2007 | 04:56 PM
HOTLAP's Avatar
HOTLAP
I replaced the cheap plastic caps that came with the bike with nice metal chrome caps with a rubber washer inside, that way if the valve does weep a bit of air I have a back up.
Old May 30, 2007 | 10:17 PM
LAZYBOY's Avatar
LAZYBOY
i will try the good caps. no loss in the last few days. damned gremlins
HDmikie
Dec 11, 2017 07:44 PM
tmac00333
Jul 29, 2013 10:43 AM
milesvdustin
Oct 18, 2011 09:33 AM
Lincoln33
Nov 5, 2009 01:05 AM
Shovelhead77
Aug 25, 2006 12:09 AM
