Looking for options on mounting boost gauge.
Old Mar 4, 2017 | 01:15 PM
Tomtalbot10589's Avatar
Tomtalbot10589
1st Gear
Default Looking for options on mounting boost gauge.
Looking for a cheap mount for boost/air pressure gauges. Seeing what everyone else uses
Old Mar 4, 2017 | 06:10 PM
Yamaharley's Avatar
Yamaharley
Not a bad idea to run a vacume gauge on the bike as I run one in the chevelle and it tells you a few different things about the health of certain things like rings and seals. Boost though is kinda useless unless you have a turbo setup or supercharger. Then you can key an eye on boost so you can use a manual boost controller to set the pounds of boost where you like it. My mazdaspeed I used to run around 11psi. 12 would confuse the ecm.
mayhem912
Apr 11, 2016 10:44 AM
06SGWA
Jan 21, 2015 03:00 PM
Ragtop
Mar 21, 2012 12:00 AM
Gringoloco13
Blowers/Turbos/Nitrous Oxide
Jun 15, 2011 10:31 PM
Ride my Seesaw
May 9, 2010 05:21 PM
