Is this normal?
Old Mar 8, 2017 | 08:28 AM
cvaria's Avatar
cvaria
Taje back to the dealer. They will fix it for you under warranty. Res ipsa loquitur
Old Mar 8, 2017 | 08:54 AM
Oddman's Avatar
Oddman
I second the key theory. that looks like something has been striking that cover. if you look at the first fin you can see the gouge and the the marks are longer right on the side corner. Aluminum is very soft. if it was corrosion, you wouldn't see some of the shiny fresh marks
Old Mar 8, 2017 | 12:52 PM
Exegesis's Avatar
Exegesis
Stage III
Fellows, you cracked the case.. the key chain was to blame for this.
It never occurred to me that my key chain would hit the valve cover and cause this.
When i looked at the damaged valve cover the key was removed from the ignition... after reading about the key being the possible culprit for this i put the key in and the markings on the valve cover match the area where the key chain would flap in the wind and strike the cover.
Thanks everyone for your input and keen eye.
Exegesis.
Old Mar 8, 2017 | 12:58 PM
Oddman's Avatar
Oddman
well I guess thats good news, bad news
now all you have to do is "distress" the rest of the covers for that "custom" look
Old Mar 8, 2017 | 01:01 PM
drinktothat421's Avatar
drinktothat421
time for a key relo kit!
Old Mar 8, 2017 | 01:03 PM
multihdrdr's Avatar
multihdrdr
Exegesis.
Your case is cracked too?
Old Mar 8, 2017 | 01:07 PM
TStephen's Avatar
TStephen
Well thanks for letting us know the culprit. I hate those posts where someone asks a question, everyone puzzles over it for awhile, then the OP never comes back on the thread to let us know what the problem was.
It's like, WTF WAS THE PROBLEM?!?!?
P.S. use a solo key.
Old Mar 8, 2017 | 01:27 PM
deadrubberboy's Avatar
deadrubberboy
Change the key ring and still try to get a new one out of the dealer. Customer is always right, right?
Old Mar 8, 2017 | 01:41 PM
TStephen's Avatar
TStephen
ALWAYS try for the free part.
Old Mar 8, 2017 | 02:56 PM
cHarley's Avatar
cHarley
FYI - the ignition switch will last a lot longer if you do away with the whole key-chain thing in the switch. All that weight flapping in the wind plays hell on the lock tumblers.
I have the one bike key on a small ring, my full key ring stays in my pocket.
