battery, charging, draw???
The trickle charger will top off the battery if its good and show you a bad which it looks like but when these intermittent issues come up you need to check fuse connections, corrosion etc, yes?
Keep us apprised and good luck,
Pretty sure she'll fire tomorrow after trickling, for at least long enough to get a running voltage reading.
David,
Yes, negative ground was fine. At the battery and the block. So far fuses seem to be good and corrosion free,...at first look.
grbrown,
I did read the sticky previously. Printed it out and brought it home along with some other print outs. But whoever wrote it should be fired because it did not make me a charging system expert.
Thanks again all. Will update ASAP.
Let battery trickle charge for 2 days now.
Voltage check bike not running = 13.4 Ok,...sounds better than other day when it was mid 12's.
Ignition on = 12.25, then Run on = 12.0 Same as other day
On startup drops to just under 9.
Once idle slowed down it settled about 14.0.
Under medium throttle drops to 13.5.
I shut bike down, waited about 10 min and checked battery with bike totally off and reading only 12.5V.
Now that I was able to get it running I was able to do the AC output for stator test. Showing 25V at idle (which is where is should be) BUT the voltage does NOT increase under throttle. What's that mean?
Few extra things to know:
- When doing the stator resistance test, I only get resistance when I go negative to positive. I thought I was supposed to get resistance either way?
- When doing the stator ground check I get a 0.00 reading when reading the negative stator terminal (which is good). When I try to read the positive stator terminal I get no reading (meter screen goes blank).
Can't figure out if I have a stator, regulator or battery problem? Or maybe a combo?
Have you had your battery load tested?
Revving the engine you should be able to read around 14.5 volts at the battery.
There are several tests which will help you diagnose the problem, if it lies in your charging system.
"if the stator is NOT shorted to ground, and the stator is putting out A/C voltage"
The sticky does not talk about the nuance issue I seem to be having with these tests. Are you reading my post or are you just busting my baby makers?
An alternative is to find yourself a local indy and ask him to check your bike over.
I'm fine if you don't want to help. Simply feel free to not participate in my threads and save us both time. Have a good day.
