Cobra fuel management
Old Mar 30, 2017 | 08:18 PM
Jonah Gilmore's Avatar
Jonah Gilmore
Stage I
Default Cobra fuel management
Has anyone tried the Cobra fuel management system? Its about $100 cheaper than the VH.
Old Mar 30, 2017 | 10:00 PM
Guzzi's Avatar
Guzzi
Cobra is ok at best. Hard to dial in with very limited settings.
Fuel Moto Micro EFI is under $200 and has 3 selectable maps with unlimited map support.
https://www.fuelmotousa.com/i-209229...00-models.html
Fuel Moto USA is pleased to introduce the Fuel Moto Micro Tuner by Dynojet. This easy to install Power Commander V based controller features easy to use software and uses Dynojet PC-V maps. The Fuel Moto Micro Tuner features a powerful range of fuel adjustments, it allows for individual cylinder tuning including the decel area of the tune, a useful accelerator pump feature, and it will store three maps which can be be switched right on the Micro Tuner unit. There are also three broad range adjustment for making in field adjustments if desired. There are hundreds of maps available covering most popular applications. Fuel Moto will also pre-program your Micro Tuner based on the modifications you have made to your bike so it is ready to install when you receive it. There is also a wealth of support available from both Fuel Moto and Dynojet Research.
Real Time tuning with Injector control of +250% -100% fuel
Very small and easy to mount (1/3 smaller than a Dynojet PC-V)
Individual Cylinder tuning with 250 RPM map resolution, up to 600 available tuning points including decel and idle.
The software allows you to easily pinpoint the specific area you want to adjust.
Stores three different maps which can be switched on the unit
Features easy to use software and Dynojet Power Commander V maps Includes USB Cable, CD ROM Software, O2 sensor optimizers, and detailed instructions Pre-programming available for your specific modifications
Old Mar 31, 2017 | 05:59 PM
drinktothat421's Avatar
drinktothat421
spend the extra why cheap out now.
garand
May 11, 2013 05:54 AM
ryno62
May 25, 2012 02:51 AM
DMV11982
Feb 13, 2010 06:26 AM
fuelmoto
Vendor For Sale Classifieds
Nov 10, 2009 12:21 PM
fuelmoto
Fuel Moto / Jackpot Mufflers
Nov 10, 2009 09:55 AM
