Fork pinch bolts
Old Mar 31, 2017 | 10:52 PM
vasalone's Avatar
vasalone
Default Fork pinch bolts
Has anyone switched out the star bolts for allen head bolts on the fork pinch bolts (upper and lower triple tree). Had to pull the front tire and while checking the torque (30-35 ftlbs) on these four bolts fouled one up. Seems like with allen head bolts would be less likely to foul up. Thinking of getting stainless.
THX
Old Apr 1, 2017 | 05:24 AM
Campy Roadie's Avatar
Campy Roadie
Better make sure they're the same grade of fastener; those are pretty critical. Using the wrong size torx or getting them off angle are the primary reasons they strip. I'd replace them with the OEM parts.
Old Apr 1, 2017 | 06:39 AM
TinCupChalice's Avatar
TinCupChalice
^^^^^^ This right here
Those pinch bolts are critical fasteners; if you've bunged one up replace it with the proper OEM bolt. If you do want stainless bolts, they must be of the correct grade which the majority of stainless steel bolts are not.
Alloy Boltz only if you want to go stainless: https://www.alloyboltz.com/catalog/index.php
Old Apr 1, 2017 | 09:27 AM
kuri77's Avatar
kuri77
So what grade are they and how do you tell?
Old Apr 1, 2017 | 09:31 AM
vasalone's Avatar
vasalone
Understood, will go with OEM.
Anyone have a link to order OEM HD parts online?
Old Apr 1, 2017 | 09:48 AM
Campy Roadie
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old Apr 1, 2017 | 09:51 AM
cHarley's Avatar
cHarley
The part number for the bolts is: 4351
You can google "Harley 4351" without the quotes
Or, HERE if your lazy.....
Old Apr 1, 2017 | 10:11 AM
HarleyScuba's Avatar
HarleyScuba
I replaced my pinch bolts with socket-head stainless, about 7 years ago. Not a problem. My turn signals were relocated to the lower tree, at the same time. The entire front end was powdered gloss black, too. Wired the bars internally, while I was in there.
Old Apr 1, 2017 | 10:26 AM
vasalone's Avatar
vasalone
Yes, that is how I fouled mine up with the turn signals on the upper tree it gets in the way of the star bit along me being careless. Don't take much to foul them damn stars I think they need to cut them 1/16" deeper. Anyway thanks to all, will order the OEM just to be cautious.
Old Apr 1, 2017 | 01:47 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
allen or regular hex head bolts, torx are junk
