I have a 1995 HD Sportster 1200. I turn the key and have no power. Checked battery and replaced the ignition switch. no lights no nothing. Any advice on what to check next?
Any luck?
Like hscic said, it's a process of elimination. Starting at the battery.
Also, "checked the battery" means what? Did you remove the cables and clean the terminals? Check the negative cable ground?
Did you check for voltage coming into your ignition switch? etc....
Take it a step at a time and let us know what happens.
