Bleeding rear brake having trouble
Old Aug 7, 2017 | 12:29 AM
Valente Sportster's Avatar
Valente Sportster
Stage II
Default Bleeding rear brake having trouble
Can't get my back brakes to bleed on 2005 883 Sportster
Old Aug 7, 2017 | 12:39 AM
Valente Sportster
Stage II
Can someone please help can't get my brakes to bleed 05 Sportster
Old Aug 7, 2017 | 02:46 AM
hscic's Avatar
hscic
what have you done to bleed your brakes? How did you get the air out of the system...there are different methods.
Here is a youtube from delboy garage on doing the front brakes...principal is the same for the rear.
I purchased a brake bleeder syringe to push fluid up into the cylinder through the brake lines instead of down since air travels up. Used brake bleeder evacuator to remove old fluid since it is difficult to pump the brake on the other side and release/close the bleeder valve at the same time.
Old Aug 7, 2017 | 06:10 AM
grbrown's Avatar
grbrown
The rear brake can be a challenge, simply because the master cylinder is level with or lower than the brake caliper. Persistence pays! There are various instruments of torture available, which promise nirvana, but there is also a Sticky in the Tech Brakes section, which may help.
Old Aug 7, 2017 | 07:37 AM
aecs's Avatar
aecs
Go slow with it. A couple of things to remember. Our Master Cylinders are fragile. Pump to hard and fast, and it will blow out the MC. Also make sure the front caliper pin went in straight, they are supper easy to cross thread and will put a bind on the caliper, bad business.
Sparky1101
Jun 6, 2017 10:32 AM
Dudepants
Apr 30, 2017 10:26 AM
Calvin1989
Jun 26, 2015 11:54 AM
kingironhead
Jul 15, 2014 03:01 PM
MY883
Jul 8, 2012 10:06 AM
