I'm not advocating one way or another about that approach. However, that thread has some good information in it. It also has some bad info as it goes along that later gets ferreted out (so keep reading).
I thought the Deimus approach may be more hassle than what was necessary. So I just used a DK Customs bypass kit with the addition of a Krankvent to account for potential failing umbrella valves. You can see it here:
The down side - if there really is any - is that this setup still breaths via the push rod tubes etc. Opinions probably vary as to if that really matters
One thing to consider with the above approaches. None account for failing umbrella valves. Umbrella valves have a reputation for having a short effective life span.
I dont have excessive blow-by just want to reroute the blow-by that I do have on the SE/AC to a catch can instead of the intake. Now if I started having excessive blow by where I was loosing alot of oil I would check the umbrella valves.
That's fine... But the main purpose of the umbrella valves is to create a vacuum in the crank case (letting air out and preventing air from being sucked back in). Consider the possibility that they could be failing (partially or completely) in that regard and yet you still might not see much oil coming out of your breathers for various reasons.
Curious, are the umbrella valves susceptible to short lifespan or failure even with the original design intent of oil and water being dumped into the throttle intake?
The lifespan of the umbrella valves has nothing to do with where the venting is routed.
The routing of the venting to the intake has to do with satisfying the EPA.
Whoa, good to know. How do I check that the umbrella valves are still ok?
One method to test if the umbrella vales are working is to: While draining crankcase oil, leave the fill plug tight, as it is draining, loosen fill plug and oil flow should increase. If it does not, they are not closing/sealing.
