Softail Rear Pulley on Sportster?
Old Aug 23, 2017 | 10:40 AM
lewk's Avatar
lewk
Originally Posted by 6 gun
... I have an 07 RKC and it came with a 66 tooth pulley, and I wanted more bottom end. i put a 2007 68 tooth Sportster pulley on my RKC and that is how I know about the changes...
Does this mean the 07 RKC pulley can be used on an 07 sportster to gain more top end?
Old Aug 23, 2017 | 10:43 AM
6 gun's Avatar
6 gun
Yes it does, but you will have to change out the mounting bolts I think you will need either longer or shorter, I cant remember it was a couple or three years ago.
Old Aug 23, 2017 | 11:32 AM
devilsbike's Avatar
devilsbike
4th Gear
awesome info 6 gun! thanks
Old Aug 23, 2017 | 12:43 PM
6 gun's Avatar
6 gun
No Problem I like to help when and where I can.
Old Aug 23, 2017 | 12:51 PM
lewk's Avatar
lewk
Yes it does...
And I see that the 07 RKC's rear sprocket comes in 2 versions. the 66T, and the 64T for japanese models. Hehehe... great choices for increasing top end.
Old Aug 23, 2017 | 12:54 PM
6 gun's Avatar
6 gun
yeah but the Jap model may have those rubber things in them to where the pully does not bolt directly to the wheel Check it out real good before you order.
Old Aug 23, 2017 | 01:00 PM
lewk's Avatar
lewk
Will do, thanx for the heads up. I'm just planning ahead for when I upgrade to 1275cc. Then I'll be ready for the RKC sprocket. Since MoCo screwed up the softail line, I feel like it's worth making my sportster more tour-capable. At least for now.
Old Aug 23, 2017 | 01:21 PM
TStephen's Avatar
TStephen
By adding two teeth to your rear pulley you will give yourself more low end torque but less top end speed. As far as speedometer your speedometer will show you running 5 miles faster than you are really going. I have an 07 RKC and it came with a 66 tooth pulley, and I wanted more bottom end. i put a 2007 68 tooth Sportster pulley on my RKC and that is how I know about the changes. FWIW, I used my stock belt, but I had to put the belt on the pulley before I put the axle in.
Not picking a fight here, but a larger pulley in the rear will increase low-end torque and lower top speed.
Think about that 10 speed bike again.
When we raced BMX back in the day, the smaller front sprocket guys always got the hole-shot on the gate drop, we could usually catch up, but that crucial quick start got them out in front at the beginning.
Old Aug 23, 2017 | 01:26 PM
lewk's Avatar
lewk
By adding two teeth to your rear pulley you will give yourself more low end torque but less top end speed ...
Originally Posted by TStephen
Not picking a fight here, but a larger pulley in the rear will increase low-end torque and lower top speed ...
You two are saying the exact same thing.
Old Aug 23, 2017 | 01:40 PM
TStephen's Avatar
TStephen
Why yes, yes we are! Thank you.
I was chewing gum while posting.
