Flat front tire
Old Oct 6, 2017 | 12:14 PM
Nate Beck's Avatar
Nate Beck
Default Flat front tire
Went out to hop on the bike and did my usual pre-ride check and found the front tire below 20 psi (manual states 30). It had sat for a week and the weather took a drop in temps from 50s/60s to 40's/50's. I know your PSI will drop a bit when it gets colder but this much seems like too much. I checked the back tire to see if it followed suit but the back tire was only down 2 psi. I pumped it back up to 30 to see if it would go down again and so far 24 hours later its still at 30. Any ideas? Could a drop in temp like that really drop the psi that much in only one tire?
Old Oct 6, 2017 | 01:05 PM
cchuck3537's Avatar
cchuck3537
I had the same thing happen to me a couple weeks ago. I am not sure what the cause was but I am interested in finding out.
Old Oct 6, 2017 | 01:15 PM
Scudda's Avatar
Scudda
Short answer ..yes. It depends on the type of rims on the bike. My guess is that this is a tubeless tire an mags. The inside rim of the mag could have some corrosion on it that when the temp dropped the metal of the mag contacted and caused a rim leak
Old Oct 6, 2017 | 02:05 PM
FMB42's Avatar
FMB42
All tires, of course, leak air over time to some degree. But that large of a diff between the F and R is a cause for concern. Btw, when was the last time you checked the pressures and what were they at that point? That said, I'd very carefully check the front for any possible Foreign Object Damage (a nail, broken glass, etc). Sometimes tires with FOD will leak far more whenever the tire is parked directly over the source of the leak. EDIT: also check the valve stem core and, if tubeless, the stem itself.
Old Oct 6, 2017 | 02:08 PM
elephantrider's Avatar
elephantrider
i have to add a couple lbs of air once a month or so on my sporty.
Old Oct 6, 2017 | 02:10 PM
wideglideCVO's Avatar
wideglideCVO
Check the stem to make sure it is tight. Soap test it after you get correct psi.
Old Oct 6, 2017 | 05:29 PM
Nate Beck's Avatar
Nate Beck
Carefully inspected and did the soap test on the tire, rim and valve stem and no bubbles anywhere. The tire is still holding 30psi from yesterday. Took it for a 30 min ride mixed between windy roads and highway speeds thinking maybe if its a small enough leak it would only leak when the tire has more pressure on it. Let the tire cool down for a few hours after the ride and checked it still at 30 psi. Do I just ride it and continually check it every few hours?
Old Oct 6, 2017 | 07:21 PM
John Harper's Avatar
John Harper
My cast rim on the front leaks air like a sieve, the rear rim not at all after 27 years. I have to use industrial bead glue to make it seal, and it still leaks down a bit. My theory is salty ocean air hitting that rim and getting pushed in to corrode the aluminum. I guess it's a common problem if you live on the coast, and we have a lot of foggy wet conditions in my area on morning rides.
The front exhaust heat shield often has a thin layer of salt on the leading edge after a foggy ride, so I assume the warm tires condense the salt along the rim and it migrates inward.
John
Old Oct 7, 2017 | 05:49 PM
heybaylor's Avatar
heybaylor
the volume of air verses the rear make's it change more , you have checked it out ,go ride it
way over thinking here
GalvTexGuy
2014-2024 Touring Models
18
Feb 27, 2021 05:24 PM
milesvdustin
Oct 18, 2011 09:33 AM
ctmedic
Apr 28, 2008 07:25 PM
Windup08
Sep 20, 2007 10:17 PM
