2011 sportster p0562 code
Old Oct 12, 2017 | 12:00 AM
znedrow4's Avatar
znedrow4
4th Gear
Default 2011 sportster p0562 code
The check engine and battery light are on at all times but nothing seems wrong with it, recently ive had the stator, voltage pack, and battery tested and nothing seems to be wrong with it other than the light being on. Any ideas as to why this light is on?
Old Oct 12, 2017 | 01:13 PM
Guzzi's Avatar
Guzzi
Google is your friend.
Type in sportster and the code.
A big list will appear with nearly identical problems and solutions.
The code does point to electrical.
Old Oct 12, 2017 | 05:07 PM
cHarley's Avatar
cHarley
There's a "Sticky" thread at the top of this section called
Updated - How To: Diagnostic Trouble Codes (DTC's)
P0562 is "Low Voltage"
Check Engine and Battery lights together usually indicate the same thing.
Typically occurs when the charging system isn't working and the battery voltage drops to around 11.5 volts.
Old Oct 14, 2017 | 03:25 PM
shanneba's Avatar
shanneba
Was the battery load tested?
Battery voltage is measured by the ECM on pin #72.
P0562 is set when battery voltage is less than
12.2V at idle and voltage does not increase when engine
speed is over than 2000 rpm.
Low voltage generally indicates a loose wire, corroded connections,
battery and/or a charging system problem.
I would check and clean the fuse box, relays, the Battery power and ground connections and the battery cables for internal corrosion. Make sure all the grounds are clean and tight, there is one behind the engine around the swing arm.
Old Oct 14, 2017 | 10:07 PM
znedrow4's Avatar
znedrow4
4th Gear
found the issue, turns out the voltage regulator was the problem. It was only working about half the time. Changed it out and no check engine or battery lights now.
gerald martin
Sep 13, 2018 08:32 AM
jjmil03
Feb 20, 2012 07:38 PM
Bsod
Jul 4, 2011 01:29 AM
dogit56@aol.com
Nov 27, 2009 12:13 AM
helstone
Sep 4, 2007 04:55 AM
