Carb rebuild
Old Oct 23, 2017 | 06:42 PM
cbacon1788's Avatar
cbacon1788
Default Carb rebuild
ordered a carb gasket rebuild kit for my 86 Sportster 883, never messed with carbs before and wondering what route to go with rebuilding this. Is there a “diy” on rebuilding a carb complete in the manual, if not how would one go about doing this with no prior knowledge... thanks!
Old Oct 24, 2017 | 06:55 AM
FreedomRider's Avatar
FreedomRider
The Factory Service Manual does have a section on rebuilding the carb ... sounds like you have a manual, just follow the steps. The carb is pretty simple and not much to mess up ... if I can do it, anyone can. Give it good cleaning with carb cleaner, take your time and follow the manual.
Old Oct 24, 2017 | 07:14 AM
Riffraff123's Avatar
Riffraff123
Best info in my book....https://cv-performance.com/harley-cv...-tuning-issues
Old Oct 24, 2017 | 12:14 PM
FMB42's Avatar
FMB42
Follow the above advice. Maintain a super clean work area (including, of course, your hands). Check it for leaks with a remote fuel bottle before you install it. Be prepared to do several 'plug' readings (with brand new plugs). BTW, I recommend NGK plugs or maybe ND/Denso and nothing else.
Old Oct 24, 2017 | 02:13 PM
John Harper's Avatar
John Harper
Make sure you get the right rebuild kit. Most of us have the 1989 and later CV40 carb with the accelerator pump, your original 1986 is not the same. I believe it was referred to as a Keihin butterfly carb. The rebuild on yours should be super easy, just remember to record the numbers on the pilot and mainjet, so you can change jets if you wish and match proper air/fuel needs. Good luck.
John
sven556
Apr 12, 2014 06:52 PM
tinnermanmark
General Topics/Tech Tips
18
Mar 15, 2014 11:48 AM
650 cooter
Exhaust System Topics
May 19, 2013 06:40 PM
BC IAN
Sep 27, 2010 02:19 PM
Merkin
Panhead
Jul 21, 2008 10:10 PM
