Suspension question
Old Nov 11, 2017 | 08:57 AM
Kenny94945's Avatar
Kenny94945
All good comments above.
OP perhaps you are bottoming out.
For rear increase spring preload or install longer shocks (or install a more "cushier" seat).
For forks, without spending a lot of money, install fork springs, add preload spacers if need be to set sag.
Be aware adding heavier weight oil will increase compression but can negatively affect rebound. Fresh fork oil never hurts and you can experiment in the oil amount added which can also alter compression and not affect rebound.
Good luck.
Old Nov 11, 2017 | 09:34 AM
misput's Avatar
misput
Originally Posted by CARSMARK813
Hey everyone, this site is great to talk with many experts in Harley maintenance. My question, I have a 2008 1200 sportster with about 9500 miles, the ride is harsh when hitting a hard bump in the road. I was wondering if the front fork oil has anything to do with the harshness of the front end. I tried putting in progressive springs but that didn't help. Any ideas what the problem if any might be?
Avoid those hard bumps and keep in mind you are not riding a Cadillac
Old Nov 11, 2017 | 11:39 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Thanks guys for the help. I will look at it and see what I can do.
Can't emphasize enough how important it is to clean out the fork tubes and damper rods by removing them, and thoroughly flushing all the orifices.
We had a Customer that changed the fork fluid 3 different times (without disassembling)... a different weight each time, trying to get his forks not to be so harsh when hitting even medium bumps.
He even flushed them with kerosene (while still assembled). It was not until he removed the springs and damper rods from the tubes that he discovered big globs of congealed fluid that were partial blocking the damper orifices.
Once he got it fully cleaned, the forks operated as designed and the ride was much improved.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Nov 11, 2017 | 02:39 PM
ApexRider's Avatar
ApexRider
I was researching those "Intiminators" last night, and they look like a next-level in design over the simple RT emulators. For the price, I'd be inclined to re-spring (based on your average weight with gear on the bike, if necessary) and try those out with recommended oil viscosity. If it's just the forks that need attention, you're looking at ~$300 + labor unless you DIY. Alternate shocks would drive the cost up quite a bit, but ultimately if you're going to keep the bike for a long time, the price/mile is worth it, IMO.
FXDWG2011
Oct 7, 2015 06:52 AM
johnsonabq
Jul 14, 2013 08:22 AM
hintonite
Jun 20, 2010 07:49 AM
hdflyer76
Jun 25, 2009 04:33 AM
GPHDXLC
Mar 18, 2008 01:13 PM
