Cruising speed
Old May 1, 2018 | 08:11 PM
Jaystn62's Avatar
Jaystn62
I agree with charley on the lugging. Even on the big twins anything under 2500 is lugging unless you're just cruising around town. If shift into 3rd at anything less than about 2900 I can feel it. It lugs.
Old May 1, 2018 | 08:35 PM
hmnavy72's Avatar
hmnavy72
This is a pretty open question....
i have about 22k miles on my 15 "72" and it has spent most of its life in the 2800-4k rpm range on the highway.
factors:
solo or two-up?
riding in a group?
any cargo?
whats the speed of traffic?
weather?
How straight is the road?
climbing hills or screaming across Kansas?
Old May 1, 2018 | 09:35 PM
shanneba's Avatar
shanneba
I'm sure Harley would never recommend "lugging the engine"
From the operating section (first 500 miles break in)
" During the first 50 mi 80 km of riding, keep the engine speed below 3000 rpm in any gear.
Do not lug the engine by running or accelerating at very low rpm, or by running at high rpm longer than needed for shifting or passing.
Avoid lugging the engine by not running the engine at very low speeds in higher gears."
There is no indication of what "very low speed" is defined as (no tach on the bike either )
Here is what they DO recommend in my owner's manual-
Shift from 1st to 2nd at 15 mph (1846rpm to 1319rpm)
Shift from 2nd to 3rd at 25 mph (2198rpm to 1635 rpm)
Shift from 3rd to 4th at 35 mph (2289rpm to 1897rpm)
Shift from 4th to 5th at 45 mph (2439rpm to 2091rpm)
So it looks like maybe under about 1900-2000 rpms in 4th or 5th gear is "too low"
Downshift from 5th to 4th at 40 mph (1859rpm to 2168rpm)
Downshift from 4th to 3rd at 30 mph (1626rpm to 1962rpm)
Downshift from 3rd to 2nd at 20 mph (1308rpm to 1758rpm)
Downshift from 2nd to 1st at 10 mph (879 rpm to 1231rpm)
I have the clutch in before 10 mph in second so it doesn't ever get to 879 rpms.
My bike will shift at the HD recommended speeds using light throttle
Here is what works better for me-
Shift from 1st to 2nd at 20mph (2462rpm to 1758rpm)
Shift from 2nd to 3rd at 30mph (2638rpm to 1962 rpm)
Shift from 3rd to 4th at 40mph (2616rpm to 2168rpm)
Shift from 4th to 5th at 50mph (2710rpm to 2324rpm)
Makes the speedo into a "GEAR INDICATOR"
The 2013 Stock Sportster EFI tune doesn't really have enough ignition advance from 1250~2000rpms at low MAP (30-50) light throttle openings.
The Stage 1 tune adds more low throttle timing (Maybe a little too much for a 2007-2013 software level 176 tune), the 2018 software stage 1 tune seems to have better ignition timing at 1500-2000 rpms at 30-50 MAP.
Just my 2 cents worth
Old May 2, 2018 | 12:22 AM
Jak_Rak's Avatar
Jak_Rak
Originally Posted by cHarley
Your bike, do as you please.
5th gear on a 1200 @ 2200 RPM = ~45 MPH - YOU ARE KILLING IT!
Read my post again. I said " cruising in top gear with the engine under light load. If I'm on the freeway and I'm scooting along at or near the speed limit, and there is no traffic to pass or hills to climb..."
Under light load means you're not accelerating, you're not passing, you're not climbing a hill. You're cruising. On the freeway. With the bike turning a very calm and respectable 2650-2700 in 5th at 60 mph. That's not lugging the engine. You mean to tell me I need to be in 4th gear at these speeds because otherwise I'm "lugging" the engine and I'll hammer the rods? I call shenanigans.
You can believe what you want, and ride how you want, but telling someone else that they're going to risk internal engine damage by riding at anything under 3000 rpm is just crap. It's irresponsible.
Sporty engines are "happiest between 3,000 - 5000 rpm"? Says who? Even the HD owner's manual (posted by Shanneba, above) says differently.
OMG THEY'RE KILLING IT!!
If you've got proof that your information is factual, as opposed to, you know, something you just believe because you read it on the internet somewhere, I'd be happy to hear it.
Old May 2, 2018 | 03:44 AM
kap1's Avatar
kap1
On long hwy trips I find the best cruising speed to be 5mph over the limit unless around big cities when I flow with traffic which is usually at least 10 over. Long periods of cruising out west I found 85 to be the limit of the 'comfort' zone--just seemed buzzy over that to me. I am usually loaded down when doing long periods of hwy cruising which I consider longer than 4 hrs. I run at 55 in fifth all the time, but think of that as the low end--for long periods.
Old May 2, 2018 | 08:11 AM
shanneba's Avatar
shanneba
If you look at the ignition advance table on the 2007-2013 Sportster stock tune you can see why the engine runs best at 3000+ rpms.
It actually has enough ignition timing for the engine speed.
I see a MAP of about 40-50ish at low throttle cruising down the highway at 50-75mph.
My 5 cents worth
Code:
2013 Stock front
RPM/map	20	30	40	50	60	70	80	90	100
1000	10	10	10	10	10	10	10	3	0
1250	10	10	10	10	10	10	10	5	0
1500	12	10	10	10	10	10	10	5	2.75
1750	12	10	10	10	12	13	13.25	8.25	6.75
2000	14	10	10	10	16.5	19.25	18	13	10.75
2250	14	12	12	14.5	19.75	24	23.25	17.5	15
2500	14	14	14	19	22.75	28	28	22.75	17.5
3000	14	14	18.5	27.25	31.5	34.5	32.5	26	21.25
3500	14	14	24	33	35.75	36	34	29	25
4000	14	14	29.25	37.5	38	38	36	30.5	28
4500	14	14	34.5	41	40	38.5	37	33	30.5
5000	14	14	39	45	40.5	39	37	34	31.5
5500	14	14	40	45	43.5	40.5	38	36.5	33.75
6000	14	14	40	45	45	45	44.5	41.5	35.75
6500	14	14	40	45	45	43.75	44	41.5	41
7000	14	14	40	45	45	45	44	42	41
7500	14	14	40	40	40	40	44	42	41
2017 HD SE Tuner stage 1
Code:
2018 stage1
F
RPMxMAP	20	30	40	50	60	70	80	90	100
1000	10.00	12.00	12.00	12.00	12.00	10.00	10.00	3.00	0.00
1250	10.00	12.00	12.00	12.00	12.00	10.00	10.00	5.00	0.00
1500	10.00	12.00	12.00	12.00	12.00	10.00	10.00	5.00	3.00
1750	12.00	14.00	14.00	14.00	13.00	13.00	13.00	8.00	8.00
2000	12.00	16.00	16.00	16.00	17.00	19.00	18.00	11.00	11.00
2250	14.00	17.00	17.00	18.00	20.00	24.00	23.00	17.00	17.00
2500	17.00	20.00	21.00	21.00	23.00	28.00	25.00	23.00	18.00
3000	25.00	27.00	27.00	27.00	32.00	35.00	33.00	26.00	22.00
3500	30.00	33.00	33.00	33.00	36.00	36.00	33.00	26.00	23.00
4000	32.00	35.00	38.00	38.00	38.00	38.00	35.00	28.00	26.00
4500	32.00	35.00	41.00	41.00	40.00	39.00	37.00	29.00	27.00
5000	32.00	35.00	44.00	44.00	41.00	39.00	37.00	31.00	28.00
5500	32.00	35.00	45.00	45.00	44.00	41.00	38.00	33.00	30.00
6000	32.00	35.00	45.00	45.00	45.00	43.00	39.00	34.00	34.00
6500	32.00	35.00	45.00	45.00	45.00	43.00	39.00	34.00	34.00
7000	32.00	35.00	45.00	45.00	45.00	43.00	39.00	34.00	34.00
7500	32.00	35.00	45.00	45.00	45.00	43.00	39.00	34.00	34.00
Old May 2, 2018 | 08:32 AM
HOTLAP's Avatar
HOTLAP
I find 70MPH is my bikes sweet spot, engine is at it's smoothest and reving high enough that there is really no need to shift down a gear even when passing on a two lane.
Old May 2, 2018 | 09:33 AM
firehawk6's Avatar
firehawk6
That is the speed mine is the happiest too. If I'm not paying attention to the speedo that is where I seem to always end up.
My 'rule of thumb' has always been if you open the throttle, and the engine/bike does not immediately begin to accelerate, and struggles to do so, vibrates excessively, etc... you are in too high of a gear for that speed. I tend to error on the side of spinning an engine faster in a lower gear. The correct gear to be in should become second nature without even having to think about it.
Old May 2, 2018 | 10:35 AM
cacomly's Avatar
cacomly
I spend a lot of time on the highway. The bike is happy at 70-75. I have plenty of power to accelerate and it just purrs right along.
However, I have noticed that anything above 60-65 mph and my fuel mileage tanks from around 50 mpg to 43-45 mpg.
My bike is heavier than any other sporty due to all the stuff I have on it plus I am running a windshield so that affects it as well. With some time you will see what speed your mileage starts to drop and choose accordingly.
Regarding the lugging, I probably shift into 5th around 55-60 mph, most of the time I wait until I am no longer accelerating. And I had 206,000 miles on my engine before I had to split the case due to a bad bearing in my transmission main shaft.
Old May 2, 2018 | 10:56 AM
lewk's Avatar
lewk
Originally Posted by firehawk6
That is the speed mine is the happiest too. ...
Originally Posted by cacomly
I spend a lot of time on the highway. The bike is happy at 70-75. ...
+4 on 70mph with mine too, in 5th. 2007 1200L if that matters.
