Fork question
Old Jun 18, 2018 | 12:56 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by Mchad
You see, that's helpful information! I am planning a dual disc upgrade and need to find a right slider and have it chromed. I was going to consider the FXDX sliders, which I now have to ask if they are compatible. I thought they would be, but hearing about the trees, makes me think...
And no, I didn't post to the CVO forum. They're a bunch of snobs over there... JK!
You really don't want FXDX slider unless you have all the other FXDX internal parts (well, unless it's from a exactly a 99 fxdx because they are just normal sliders and weren't adjustable) ... You just want a 1999-earlier (earlier to a point) 39mm Right slider with Caliper mounts... most likely will come from a Dyna or FXR. Can come from a Sportster, but right now I can't think of any 99-earlier (to a point) Sportsters with dual disc that weren't The "S" model adjustables. I might be forgetting though, have to look later
EDIT: Looks like those Right Sliders are Not Available NEW anymore either...You'll be looking for USED and it's part# 45922-87 (if needed)
Old Jun 18, 2018 | 01:11 PM
Mchad's Avatar
Mchad
You really don't want FXDX slider unless you have all the other FXDX internal parts (well, unless it's from a exactly a 99 fxdx because they are just normal sliders and weren't adjustable) ... You just want a 1999-earlier (earlier to a point) 39mm Right slider with Caliper mounts... most likely will come from a Dyna. Can come from a Sportster, but right now I can't think of any 99-earlier (to a point) Sportsters with dual disc that weren't The "S" model adjustables. I might be forgetting though, have to look later
Ahh, I forgot about the adjustables on the FXDX. Ok, Back to the drawing board. FXR lowers I guess.
Old Jun 18, 2018 | 01:21 PM
multihdrdr's Avatar
multihdrdr
Look at my last post again...I did some editing.
And don't get caught up in "FXR" (you would probably end up paying more) ...Dyna uses the same ones
Old Jun 18, 2018 | 01:26 PM
Mchad's Avatar
Mchad
I looked it up and I saw 45923-87 though. Whats the difference?
Old Jun 18, 2018 | 01:31 PM
multihdrdr's Avatar
multihdrdr
45923-87 is a run-of -the-mill Right slider with NO Caliper Mounts...just like you have already
Old Jun 18, 2018 | 01:33 PM
Mchad's Avatar
Mchad
Damn Ronnies, It showed it with caliper mounts. I guess "Product may be different then photo" huh.
Thanks.
Old Jun 18, 2018 | 01:42 PM
multihdrdr's Avatar
multihdrdr
Exactly...the illustrations are helpful, but don't bank on them being accurate in every case. I find a lot of errors, but typically doesn't effect me...
Here's one... Dyna 49mm slider...several problems with that one...but the glaring one for anyone should be the Two fender mounts on a single slider
Old Jun 18, 2018 | 02:16 PM
Mchad's Avatar
Mchad
Yeah, this is going to be fun. I can't find a reasonable 45922-87 anywhere. There's a pair on eBay for $675, but no way am I paying that. I'll just keep looking...
Old Jun 18, 2018 | 02:45 PM
multihdrdr's Avatar
multihdrdr
Yeah, that was probably Elvis...he wants a lot for his stuff
Your best bet is to keep looking like you said, but know which are the correct ones just by looking because most (especially the cheaper ones) won't be listed by # and also not by "Complete" fitment if included at all...
If you find any that are questionable, send me some info/photos...I should be able to identify them
Old Jun 18, 2018 | 02:48 PM
Mchad's Avatar
Mchad
Will do, thank you Sir.
