Extended throttle cables problem
Old Jun 7, 2018 | 07:13 AM
AMP'd's Avatar
AMP'd
Default Extended throttle cables problem
Installed extended throttle/idle cables with a set of 12" apes and while all went as flawless as it could have, I noticed yesterday on the turnpike that once in fifth gear if I try and go full throttle my RPM's raise but the bike wont go past 60/65 mph.
Any suggestions on what I may have missed?
Thanks in advance.
Old Jun 8, 2018 | 05:56 AM
RRider's Avatar
RRider
Sounds like your clutch may be slipping
Old Jun 8, 2018 | 08:58 AM
AMP'd's Avatar
AMP'd
Is it possible I may need to readjust the clutch cable again? Clutch feels fine and it only seems to do this when I'm in 5th gear, im thinking I may need to readjust the the clutch adjustment screw under the spring under the derby cover.
Old Jun 11, 2018 | 05:32 AM
AMP'd's Avatar
AMP'd
Readjusted the clutch cable, problem still happening. Any other suggestions?
Old Jun 11, 2018 | 06:35 AM
shanneba's Avatar
shanneba
Does your throttle butterfly open fully? Have you taken the air cleaner off to verify?
How to adjust the cables on an EFI Sportster- (Not sure if you have a EFI or carb)
Old Jun 11, 2018 | 09:05 AM
cHarley's Avatar
cHarley
You haven't supplied the Year and Mileage on the bike.
It definitely sounds like the clutch is slipping (5th gear issue), but we need more info.
Old Jun 11, 2018 | 09:19 AM
AMP'd's Avatar
AMP'd
Ill definitely give that a look, ill remove the air cleaner again and verify.
Its a 2017 iron 883, about 3k miles.
Old Jun 11, 2018 | 09:20 AM
AMP'd's Avatar
AMP'd
Old Jun 11, 2018 | 07:07 PM
AMP'd's Avatar
AMP'd
Readjusted throttle/idle cables and also readjusted clutch as per manual.
Took it out for a ride... FLAWLESS.
Incredible how great it rides now, smooth shifting, no slipping.
Thanks for the guidance dudes.
steelerdude1
May 22, 2014 11:04 PM
alika808
Mar 4, 2013 01:26 PM
cjbmustang
May 26, 2010 08:50 AM
sledhead140
Mar 5, 2009 07:13 AM
Ash
Apr 10, 2007 04:16 PM
