starting
Old Jun 26, 2007 | 08:51 AM
hull's Avatar
hull
Stage II
Default starting
1973 xlch with kien carb. Starts with 3-5 kicks when it is cold but after shutting down it will not kick over. Any ideas.
Old Jun 26, 2007 | 09:34 AM
cHarley's Avatar
cHarley
Default RE: starting
That's not much to go on. What is the condition of the plugs? Don't use any choke. Don't twist the throttle, you'll flood it.
What have you done so far to try to resolve the problem?
Old Jun 26, 2007 | 10:54 AM
hull's Avatar
hull
Stage II
Plugs are new timing is right on.
Old Jun 27, 2007 | 09:30 AM
rh8234's Avatar
rh8234
I had a 72 XLCH many many years ago and still have the wrecked right knee to prove it. On mine, when it was hot, the best way to start it was to just barely crack the throttle (never twist it, just crack it ever so slightly), hold it there and one to three kicks it usully fired up. No choke! If it didn't fire up after three kicks, smoke a cigarrette and try again.
Road Star
Carburetor Related
47
Apr 8, 2024 09:00 AM
tyallen9
May 16, 2020 01:51 AM
MGN54
Nov 7, 2010 07:00 AM
Hey Zeus
Ironhead
Dec 11, 2006 10:08 AM
raaaaaa
Jun 20, 2005 02:30 AM
