Starter CLACK?! Before you panic.......
Old Jul 2, 2018 | 04:01 PM
IGYA's Avatar
IGYA
6th Gear
Default Starter CLACK?! Before you panic.......
For weeks I dealt with with the initial starter pause thing with my '05 1200 Custom, then it would spin over and crank. Finally, nothing but a loud CLACK. Fully charged battery, bright lights, strong horn...but no starter action. PANIC TIME! But I decided to start with tightening all battery connections and BEHOLD....a loose battery positive post connection. Tightened it up and REJOICE, not even a pause upon cranking, just instant rumble. Lesson learned: Pay attention to what gear-heads suggest and start with positive and negative connections before you do a total meltdown.
Old Jul 3, 2018 | 12:03 PM
grbrown's Avatar
grbrown
Thumbs up
Well done for sorting that out. More common seems to be the frame end of the negative battery cable coming lose, but it sounds like you were lucky - and wise!
Old Jul 3, 2018 | 12:25 PM
Kev618's Avatar
Kev618
6th Gear
Same thing happened to me yesterday! About 3 days after I changed my bars. But first thing I checked was the battery terminal and of course it was loose! Prob from pushing around the wires all the time to make sure the side cover is on tight.
Old Jul 3, 2018 | 12:36 PM
IGYA's Avatar
IGYA
6th Gear
Yep, in fact, that ground was what I set out to check but the positive connection was so loose that there was actually a visible gap between the hex-head and washer. So far, that's the only issue that I've had for it's 31,000 miles except for a tiny speck of trash in the main jet. That also was a quick and easy fix. I guess what I'm suggesting to all riders is, before towing your bike to the dealership, stop, take a deep breath, read the manual, check this forum, and most importantly, DON'T PANIC! You guys are a huge wealth of knowledge! THANKS!!!
Old Jul 3, 2018 | 12:40 PM
Kev618's Avatar
Kev618
6th Gear
Btw, since I didn't have my fork bag back on yet, I rode around with a 11mm wrench in my front pocket to be safe. I'm sure some people thought I was digging my bike a little too much!!...But it was a pretty big wrench anyway, I'm sure the chicks were impressed!
davidpisano
Sep 6, 2013 09:24 PM
martinez_nc
Feb 23, 2013 02:35 PM
sportyfrahm76
May 31, 2012 01:10 AM
cadore
Mar 11, 2010 07:32 PM
JonnyDeluxe
Jul 13, 2009 04:49 PM
