2001 1200 Sportster stopped firing
Old Aug 11, 2018 | 10:12 AM
Acts2's Avatar
Acts2
3rd Gear
Default 2001 1200 Sportster stopped firing
I rode my Sportster about 10 miles this morning. It was running fine. I stopped, and got off for a few minutes. Got back on, and it turns won’t crank. It is NOT firing at all. Kill switch on handle bar is ok.
Old Aug 11, 2018 | 10:43 AM
HOTLAP's Avatar
HOTLAP
What does "turns not crank" mean?
Does it turn over at the normal speed but doesn't start? Have you check for fuel? checked for spark?
Old Aug 11, 2018 | 11:07 AM
Acts2's Avatar
Acts2
3rd Gear
Yep! It had plenty of gas. Motor turned off normally. Really strange. It had no spark. I took the fuse box out, and checked all 4 fuses. No blown fuses. Put it all back together. Checked again .. and I had spark. It cranked right up. PUZZLED??
Old Aug 11, 2018 | 11:10 AM
HOTLAP's Avatar
HOTLAP
I'm not that familiar with the older generation but I think there was an ignition module that was prone to quiting when it got hot and would start working again when it cooled.
Old Aug 11, 2018 | 11:28 AM
Zateeva's Avatar
Zateeva
Mine did the exact same thing........ended up being my white wire, right side ignition coil, was loose, crimped it and no problems since
txphatboy
Jul 29, 2018 10:27 PM
Mikey J
May 31, 2017 05:03 PM
workn4livn
Sep 29, 2013 08:36 PM
tasker26
Aug 26, 2012 06:45 AM
leadtheway
Dec 28, 2011 06:26 AM
