I bought mine with that exact set up and it was always a surging/ jerky ride at steady state throttle. You're right, it was like a guy just learning how to ride. I tried different tunes and adjustments from V&H on the fuel pack. nothing helped. I tried the fuel pack with the stock exhaust, same surging. Tried IED's, same thing. I read somewhere about the closed loop algorithms causing surging which is why I went with Fuel Moto's Micro EFI. It's a piggy back fuel only controller but it disconnects the O2 sensors so no closed loop.
Their initial tune was OK but I manually fine tuned over time and got rid of all the surging and it runs great.
If you really like the short shots then I would suggest trying the Micro EFI or go full bore and get the Power Vision Tuner. It has auto tune features that you can use to fine tune and flash your ECU, I think you can also program it to ignore the o2 sensors of you want.
Thanks!! Great to know as I was thinking of selling the Sportster - now I believe that it is my setup that my cause the jerky ride (and that is soooooo irritating!) I now have hope! Thanks!
as to the harshness of the ride, I went with Progressive 412 shocks. 12.5" I think. I went with the longer than stock shocks because they came with softer springs. Made a world of difference.
There are even better options out there, but the 412's knocked the edge off enough for me.
Very interesting info regarding the short shots and the FP3.... I thought this was quality stuff?? The bike has both.... What other tuner is there apart from the V&H FP3?
Dyno jet Power Vision did the trick for my 2012 1200custom
Yes, Sportster OEM suspension many regard as not great, including myself. Treat it as a rigid frame.
Not smooth below 2500 rpm is concerning, that does not seem right.
On warranty? Check swing arm bolts, motors mount, eg: the critical fasteners from the workshop manual.
Many concur an air/ fuel tune, intake and pipes "smooth out" an engine.
Next mention of nervousness, longer shocks, 200 width tire. Wider 200 tire is a major modification.
IMO You are going "down the rabbit hole" of customizing and it's your choice.
It appears a more precise description of "not smooth" is actually a "surging" sensation at those RPMs. This seems somewhat common with EFI bikes, which a proper tune should solve, perhaps needing an aftermarket tuner or dealer reflash of the ECM.
You're finding that the Sportster is a completely different animal then pretty much all the other bikes. Only thing it has in common is the brand name. With that said, I like my bikes with power in the upper rpm range vs the bigger bikes. I also like that I don't feel like a midget while riding my Sporty. People say the Sporty is small,..but at 550lbs I disagree. Small compared to a 750lb Fat Boy,....I'll give you that. That doesn't mean I don't like the big bikes. I'd love to have one as a 2nd bike.
You really cannot compare the 2.
The Sporty does seem to be less forgiving when you start installing crapy components,...like short pipes. I changed from short pipes to a quality 2 into 1 and saw a dramatic improvement in low end tq and 1st/2nd gear light to light (lower rpms/cruising).
As for suspension,...yeah,...get ready to dump about $800-$1000 (parts alone) into front and rear if you want it to feel anything like a dialed in big bike. A good seat does wonders as well. Good as in good for you,..not just name brand. Width, padding, shape.
Good luck.
Just Out of warranty.... but it is a fueling issue I think... it has a V&H FP3 + V&H Short Shots + breather... It does pull like a freight train though!! Smooths out after 2500 rpm.... below that it sounds like missing a beat on a regular basis. I checked the compression and it is 100%.
I agree on the 200 tire and the rabbit hole.... but the thin 150 looks rather silly....
I have a few bikes in the garage including a BMW R Nine T 1200.... it is silky smooth compared to the Sportster and has zero issue pulling the bike in 6th from "low" revs... I just thought the Sportsters of yesteryear had soft suspensions and the motors were smooth (and I'm not talking vibrations here....) - maybe I'm confused with some other HD I had way back...
John
Thanks John. Ran a few different maps already.... it is currently the best I can get it. The culprit may be the V&H combination of pipe, FP3 and intake...
Too much to change then.... it should be much better out of the box.... I'd rather then sell it and probably get a Indian Scout which seems to be a very good bike as I understand. I am 6'6 and probably too tall for the little bike.... my wife also rides it but had a bout with cancer and a bladder op.... so the hard ride is not good.
