Normal noises?
Old Dec 30, 2018 | 10:39 PM
handirifle's Avatar
handirifle
Default Normal noises?
So the valve train on my '07 1200 seems pretty loud, especially climbing hills, two up. Is this normal?
Old Dec 31, 2018 | 02:19 AM
lewk's Avatar
lewk
Can you post a sound clip?
Old Dec 31, 2018 | 03:42 AM
handirifle's Avatar
handirifle
I don't think so. Only time I heard it was climbing a hill, riding 2 up. No free hands to record.
Old Dec 31, 2018 | 07:58 AM
harley506d's Avatar
harley506d
More than likely it's detonation which if it is, needs sorting asap.
grbrown's Avatar
grbrown
Do change down a gear, to keep your engine in its sweet spot, when climbing.
You mention in another thread that you didn't change your shocks pre-load prior to your duo ride, to which I will add tyre pressures. Something H-D neglect IMHO (I've only owned them since the '70s) is when adding a passenger or lots of luggage also adjust tyre pressures to suit. Your tyres, especially the rear, will squash more than normal with Mrs H on board (no slur intended regarding her modest weight!), which in turn will add extra drag. That will be most noticeable when climbing hills. Extra pressure is something to experiment with, starting with a couple of extra psi in the front and say 4psi extra in the rear.
Old Dec 31, 2018 | 09:01 AM
Kenny94945's Avatar
Kenny94945
Without sound it is all guessing.
1) Downshift - lugging detonation noise
2) Oil too hot and thinned out - rocker clacking noise
3) Something loose.
Only questions OP can answer I suppose is what weight and oil type is being used?
What RPM or gear and speed are they running when the noise occurs?
Old Dec 31, 2018 | 11:14 AM
HOTLAP's Avatar
HOTLAP
^+1, I agree, that's exactly when you would expect detonation which may in part be caused by too low RPM under heavy load and/or poor quaity fuel.
I would try a higher octane fuel and drop a gear to keep the RPM's up, see if that helps.
Old Dec 31, 2018 | 11:38 AM
handirifle's Avatar
handirifle
Hmm detonation is a bad thing. I run 91 octane all the time and keep tires up to max. I did forget to up preload as I mentioned. Hard for me to tell with full face helmet and exhaust sound. I did downshift but with no tach on board I have no idea the RPM. Would only be a wag. I do run the Vied fuel system but that does nothing to timing to try and adjust that. Not sure if sportys have anti knock sensors.
I noticed a few days ago climbing the same hill solo the exhaust noise turns to a drone that makes it hard to discern other noises.
Will keep my ears open for knock noises and try to find a way to record them if it occurs again.
Old Dec 31, 2018 | 06:43 PM
whylee's Avatar
whylee
Try a good octain boost. Just know that even though it will raise the octain rating, it breaks down quickly and only lasts a couple days once added.I would add some, them go for a ride and see how it responds, it does sound like detenation, as lean as these bikes run it does not take much of a load for the combustion chambers to reach very high temps.
Old Dec 31, 2018 | 09:50 PM
handirifle's Avatar
handirifle
Rode to town today and not sure it is bike noises. I mounted my phone holder today and ran power to it, so hopefully soon can do a sound clip to listen. Realized I hear a LOT of wind noises and some bike noises, hopefully a sound recording will sort them out.
HarleyGirl333
May 22, 2019 06:34 PM
BIGJPW
Engine Mechanical Topics
Feb 24, 2019 08:20 AM
Denno1064
Welcome Area Only
22
Dec 15, 2018 11:20 AM
SFO FXR
Welcome Area Only
24
Sep 26, 2018 06:14 PM
Brethrenchad
Welcome Area Only
22
Sep 26, 2018 06:06 PM
