Storage question
Old Jan 19, 2019 | 04:12 PM
Ernie DeBord's Avatar
Ernie DeBord
Default Storage question
New 1200 Iron, tucked away in my heated shop for the winter. Startron fuel stabilizer, batt tender, setting on wood all that stuff, Well...… I don't like the fuel pump just setting there for a couple months, cant be good fer it. Im thinking of turning the key on "run" and let the pump build pressure, I think that would be a "good thing", thinking of maybe doing it once a week, as im working right beside the bike. BUT I got to thinking.....If I do that will it just cycle the pump, or would that also cause the injectors to "pulse"? If so I think that would be a very BAD thing to do, as that would keep washing down the cyl walls. Any tech out there know ?Regards "Big E"
Old Jan 19, 2019 | 04:36 PM
apache snow's Avatar
apache snow
You are overthinking things. It will keep. If it bothers you just get it out and ride it every once and a while. If its in the 40s and the sun is shining I will ride mine.
Old Jan 19, 2019 | 04:44 PM
John Harper's Avatar
John Harper
I've yet to read about any problems letting the pump sit over winter. Sounds like you've got it prepared well. Good luck.
John
Old Jan 19, 2019 | 05:15 PM
Ernie DeBord
Yep I maybe overthinking.....a little. I was curious if the injectors "pulse" when you just turn the key to run, of if they wait to cycle when the engine is cranking? Just a little info to be handy for a mechanic to know. I have heard, and I hope to know fer sure, that HD fuel pumps and ecms are "marine" grade? If so that's a blessing, as a Auto Tech for many years, I have replaced a few pump and related "stuff", Regards "Big E"
Old Jan 19, 2019 | 05:18 PM
Ernie DeBord
OH, I have the Bike better than showroom condition & stored well, Also gonna be close to 0 here for a few days, Don't plan to get it out til the end of Feb, I like to ride a much as anyone, but not in this weather
Old Jan 19, 2019 | 11:56 PM
whylee's Avatar
whylee
As far as I know, the injectors do not spray any fuel by just keying the ignition on.
Old Jan 20, 2019 | 12:46 PM
halfmt1's Avatar
halfmt1
I do this myself over the winter, haven't had any problems.
Old Jan 21, 2019 | 05:35 AM
shanneba's Avatar
shanneba
The injectors will not be fired until the ECU gets an input from the CKP (crank position sensor.)
I confirmed this on my 2013 Sportster by logging data on a cold start, no injector pulse until after the battery voltage drop
indicated the engine was cranking.
This is from a 2013 Electrical Service manual:
Without the presence of the CKP signal, the ECM will not allow the ignition and fuel injection operation.
The ECU uses piston compression slow down events of the crankshaft to determine engine phase.
Therefore, the spark plugs must be installed when checking for spark.
Old Jan 21, 2019 | 02:10 PM
Ernie DeBord
THANKS SHANNE, exactly what I was hoping to learn ! I tought that was the answer, but wasn't sure. I don't want the pump just to set idle all winter, I know on automobiles they can "stick", in fact im gonna go out to my shop and cycle mine right now ! Thanks again!
Old Jan 21, 2019 | 03:54 PM
grbrown's Avatar
grbrown
Red face
IIRC you will find storage instructions in your owners manual. It doesn't amount to very much, in fact yours is plainly enjoying 5 star treatment, so don't fuss! I've owned bikes for over 50 years and have never done a great deal in the way of 'storage' when not riding any of them for a few months. I haven't had one let me down yet.
Damn - what have I just said.....
