Belt preference/recommendation?
Old Mar 26, 2019 | 03:06 PM
Packgrog's Avatar
Packgrog
Originally Posted by cacomly
All my work is done by Bikes Built Better in Horsham. Not sure if it is closer or not but it's a small shop and the main mechanic is one of the owners. They are the only ones to work on my bike other than I unless something goes wrong when out of town. Several of the staff are Sportster riders as well. Consider heading down and chatting with them.
They're about 20 minutes away, but not bad. Seem to have good feedback, and better hours than a more local place I found. I'll definitely keep that in mind! Much appreciated!
Old Mar 26, 2019 | 03:34 PM
grbrown's Avatar
grbrown
Exclamation
Those belts are known to do 100k miles, as long as you don't go drag racing, so stop spending money for the sake of it! As for replacements, the few belts I've replaced have always been H-D - I even have a Sporty belt on my modified Glide!
Old Mar 26, 2019 | 03:37 PM
Packgrog's Avatar
Packgrog
HAH! Well said!
My concern was more a matter of trying to keep OVERALL spend lower, in the event that I'd have to change it anyway. But I do get your point. Problem Anticipation is my Achilles Heel. :P
Old Mar 26, 2019 | 03:40 PM
TStephen's Avatar
TStephen
Originally Posted by Packgrog
I'm up in the Lansdale area. Nearest Cycle Gear store is up in Allentown. I'll see if I can pull the wheels myself and get them up there. If the existing belt looks sketchy, I'll grab one from there when I'm up there.
That said, if you know somewhere closer with similar pricing, I'm all ears!
Small world. My wife's family is from Harleysville, though they've all moved to SC now. Haven't been up that way for over a year now.
BTW, you can't go wrong with an H-D belt.
Old Mar 26, 2019 | 04:21 PM
grbrown's Avatar
grbrown
Thumbs up
HAH! Well said!
We're here to help! I've owned belt-drive Harleys and Buells since 1990 and have three bikes at present. I've only HAD to replace one, due to stone damage, another due to gearing change - I've never actually broken or worn one out.
Old Mar 27, 2019 | 07:59 AM
cacomly's Avatar
cacomly
Sure. I like the idea of using a smaller shop where the owner is onsite and working. Larger shops or chains everyone is just an employee. When the owner is there his name is practically on every bike and he (should) ensure that no stupid mistakes are made like forgetting to tighten something. I probably could save money by shopping around for tires each time I needed them or taking my wheels off and carrying them it for tires, however I like building a relationship with a shop. I've called with an urgent need for a tire or state inspection just before leaving for a trip and they will slip me in. That would be unlikely for a shop where they didn't know me.
If you want to run down let me know in advance and I will try to meet you there.
Actually on my 2006 Sportster I had one break at 68K and the second I replaced somewhere around 120K (total miles, not miles on the belt) due to damage. I am on my 4th belt with 245,000 miles on the bike. The third I replaced so I'd have a spare to carry with me on some rides as it is normally easier to put a belt on when it is used rather than new.
I have a slightly different usage profile than the average Sportster (or Harley) rider in that I compete in rallies including the 11 day long Iron Butt Rally. These put me in the middle of nowhere. Should a belt break then I'm out of luck so I 1) will not tolerate any damage and 2) always carry a spare because not all dealers stock them. I also carry the tools to change a belt on the side of the road during the Iron Butt Rally. No way I am not finishing due to a broken belt
Also, I was looking at the belt on my 2007 Sporty that I acquired last year with 20,000 miles on it. The belt showed signs of cracking, possibly dry rot. I need to look at it again but may replace it to be certain.
Old Mar 27, 2019 | 08:33 AM
Packgrog's Avatar
Packgrog
I did send a message via their website inquiring about pricing at least for inspection and tire replacement. If it's not TOO crazy of an added expense, I'd happily pay a little extra for the convenience of a one-stop experience. If I'd be looking at $200+ extra just for tire install, I'd just borrow the coworkers jack and take the wheels to Cycle Gear. At least for now. The bike itself may have cost me next to nothing, but all the other up front costs are hitting me like a ton of bricks. I still don't know how much a tune-up would cost, even if I at least do an oil change myself (looks easy enough from videos, just have to get the necessary stuff to a different parking lot, heh). And if I do wind up heading down to BBB, I'll send you a PM.
Holy crap that's a lot of miles! Good to know that these things really can last if properly cared for. My usage will be more stop & go, as I'm hoping to use this for my commute to Conshy (if that damned Butler Pike sink hole ever gets fixed, I have the perfect route already planned). I'm thinking that, once I can finally get the license plate so I can get out on the street, job 1 will be Seafoam in a full tank of gas to try to clear any residual gunk that might be making it take so long to warm up, then oil change after I run out that first tank, then get it to wherever (possibly BBB) for inspection and tune-up.
Dry rot is my concern with the belt, after spotting cracks in the front tire sidewall. This is a 2003 that has spent a lot of time in storage. In the South. And with only 5300 miles on it, I suspect it's original. Thus the original question. All the feedback from you folks has been extremely helpful, though!
Much appreciated, folks!
Old Mar 27, 2019 | 02:16 PM
TStephen's Avatar
TStephen
..... The bike itself may have cost me next to nothing, but all the other up front costs are hitting me like a ton of bricks.....
I'll help a brother out and take it off your hands for a few hundred bucks. The weekend is just ahead, you could spend the money on something fun.
Old Mar 27, 2019 | 02:22 PM
Packgrog's Avatar
Packgrog
*swats your hands* MINE! Just because I'm prone to obsessing over improvement tweaks doesn't mean I'm not itching to ride! Part of the problem is having more time for research than actual riding. The other problem is being stuck waiting to get the paperwork done for it to be road legal. *grumble*
Bright side: Even though I can't yet ride *MY* bike, part 2 of the MSF riding course is Saturday, so at least I'll get to ride SOMETHING, even if it's just a little Suzuki. And the weather looks to be amazing.
Old Mar 27, 2019 | 02:24 PM
TStephen's Avatar
TStephen
Damn! I thought I saw an opening when you mentioned the money aspect.
You just bought yourself a money-pit, you know that right?
I honestly think Harley owners generate a major percentage of the national GDP.
