Rear brake problem
Old Apr 10, 2019 | 07:22 PM
HOTLAP's Avatar
HOTLAP
Yes I thought they had changed that at some point.
The master cylinder plunger is machined and the cylinder it goes into is precision machined too, although it’s very strong when pushed straight in, it is very succeptable to damage from side forces. I would get down with a trouble light and closely inspect the linkage to master cylinder connection, while observing push the brake pedal and see what’s happening, it should be smoothly pushing directly inward on the master cylinder plunger.
Old Apr 10, 2019 | 07:25 PM
HOTLAP's Avatar
HOTLAP
Also make sure the master cylinder itself hasn’t been moved from its original position, if it got moved the linkage won’t be pressing the plunger in the proper direction.
Old Apr 10, 2019 | 07:29 PM
RANGER73's Avatar
RANGER73
The more it drags the hotter it gets, the hotter it gets the more the fluid expands, the more it expands the tighter the brake gets
Old Apr 10, 2019 | 07:54 PM
Mohammed Alyahya's Avatar
Mohammed Alyahya
Nothing was touched on the brake system beside the brake pedle.
i just checked it and its pushing backwards as it suppose to.
Old Apr 10, 2019 | 08:40 PM
HOTLAP's Avatar
HOTLAP
No ABS on your bike right?
Old Apr 10, 2019 | 08:54 PM
Mohammed Alyahya
It has ABS fortunately i think haha
Old Apr 10, 2019 | 09:42 PM
HOTLAP's Avatar
HOTLAP
This may be something that you might have to trailer it to a dealer, I think there are speciality tools to diagnose the ABS system.
I wouldn’t ride it there with the risk of the rear brake locking up.
Old Apr 10, 2019 | 09:45 PM
Mohammed Alyahya
Im thinking of doing the last solution and getting ready to be ripped off.
Thanks for ur thoughts.
Old Apr 10, 2019 | 10:16 PM
tmultra's Avatar
tmultra
could it be something as simple as the rotor is warped. My front rotors got warped and were pushing the pads outward so didn't have pressure until I pumped them.
Old Apr 10, 2019 | 10:19 PM
Mohammed Alyahya
i was thinking of that so i checked it and it is where it suppose to be, also brake pads still got over 30%
